Trying to use a Data Directive to write the ordernum to UD24.key1. I’m using the OrderHed to try this, but it’s not allowing me to bring in the ud24. Should I go the other way and use ud24 data Directive?
Note:. Trying to limit the ordernum write to OrderHed.ordernum changes from zero to any. This way it should only write new orders.
Normally I’d do something like that in a Method directive, using Preprocessing (on the Update method) to flag that the Order changed (if OrderNum has changed from 0 to Any then set a flag) then in PostProcessing do the actual work.
In PostProcessing, you should be able to reference the UD24 table similar to this: (partial code from a BPM we use for suppliers and UD07)
