Hello,
We currently have 1 users that is not able to load the Order Tracker menu. When the user opens the screen, the application errors out and crashes Epicor application.
Event Viewer Error
Log Name: Application
Source: Application Error
Date: 2018-08-02 9:18:03 AM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: CPR01716.clearpath.ai
Description:
Faulting application name: Epicor.exe, version: 3.1.600.17, time stamp: 0x5a149dfc
Faulting module name: clr.dll, version: 4.7.2600.0, time stamp: 0x59d78b0a
Exception code: 0xc00000fd
Fault offset: 0x0001d075
Faulting process id: 0x233c
Faulting application start time: 0x01d42a63280d70da
Faulting application path: C:\Epicor\ERP10.1Client\Client\Epicor.exe
Faulting module path: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
Report Id: 45bfc255-238d-4436-89ea-2f502b662c8f
Faulting package full name:
Faulting package-relative application ID:
Event Xml:
1000
2
100
0x80000000000000
22501
Application
Epicor.exe
3.1.600.17
5a149dfc
clr.dll
4.7.2600.0
59d78b0a
c00000fd
0001d075
233c
01d42a63280d70da
Troubleshooting steps completed have been but all work as expected
Have another with same permissions try to access the Order Tracker.
-Opens successfully -
Have user try to login on another Laptop and open the Order Tracker.
-Issue persists, crashing Epicor application
Other Steps that have been done:
Settings > General Options > Clear Client Cache
Settings > Home Page > Reset Layout
Issue seems to happen when it shows Loading Layouts. Is there anything else I can do to reset the layout on the user profile or that could be causing this to crash?
Any help would be appropriated.
