Order not Invoicing
Hi Jonathan,
We use alternate bill to and we pull in invoices by customer and select
which packing slips to pull into the batch. We had the same problem a
few days ago and we found out that we had to change the selected radio
button from Bill To to Sold To (or the other way around, I don't
remember) on the Get Shipments screen in order to pull in the invoice.
Hth,
Linda
Of Jonathan Lang
Sent: Friday, June 19, 2009 9:35 AM
Subject: [Vantage] Order not Invoicing
Good Morning all,
I have an order that will not Invoice.
1. Job completed with the proper amount of finished product
2. Order was shipped correctly
3. Job is still Open
4. Order is Closed
Everything looks correct but there is no Invoice for the Order. Any
ideas are appreciated.
Jonathan Lang
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Good Morning all,
Â
Â
4. Order is Closed
Â
Everything looks correct but there is no Invoice for the Order. Any ideas are appreciated.
Â
Jonathan LangÂ
Fax: (920) 682-7699
Â
Double check the ship date on the pack slip.
Thanks~
Kathleen
360/ 453-3445
Of Jonathan Lang
Sent: Friday, June 19, 2009 6:35 AM
Good Morning all,
4. Order is Closed
Jonathan Lang
Fax: (920) 682-7699
NOTICE OF CONFIDENTIALITY: This e-mail message, including attachments, is for the sole use of the intended recipients and may contain confidential and privileged information. If you are not an intended recipient, please contact the sender by reply e-mail and destroy all copies of this message, including attachments. Any unauthorized review, use, disclosure or distribution is prohibited.
The Ship Date is correct. It is dated 6/18/2009.
--- On Fri, 6/19/09, Kathleen Tyrrell <ktyrrell@...> wrote:
Subject: RE: [Vantage] Order not Invoicing
Date: Friday, June 19, 2009, 9:29 AM
Thanks~
Kathleen
360/ 453-3445
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Jonathan Lang
To: vantage@yahoogroups .com
Good Morning all,
4. Order is Closed
Jonathan Lang
Fax: (920) 682-7699
Is the 'shipped' (ReadyToInvoice) flag checked on the ShipHead record?
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jonathan Lang
Sent: Friday, June 19, 2009 10:38 AM
Thanks~
Kathleen
360/ 453-3445
Of Jonathan Lang
Good Morning all,
4. Order is Closed
Jonathan Lang
Fax: (920) 682-7699
Also check the billing for the customer to make sure you CAN invoice.
Customer maintenance, Billing tab, Field is Billing Days, make sure it
is set to "all days".
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Kathleen Tyrrell
Sent: Friday, June 19, 2009 9:29 AM
Thanks~
Kathleen
360/ 453-3445
Behalf
Of Jonathan Lang
Good Morning all,
4. Order is Closed
Jonathan Lang
Fax: (920) 682-7699
