Order Entry Customization
We have a few orders we do that are pretty much the same set of
information everytime that I was hoping to create a few buttons to have
auto-populate the orderdtl lines.
Before I get much further into this process, I thought I'd see if you
guys had recommendations for a better way, or if my route is the way to
go. Here's a copy of my test code from the button click event:
Dim salesAdapt As SalesOrderAdapter = New
SalesOrderAdapter(SalesOrderForm)
Dim OrderNum as string = 20000
Try
salesAdapt.BOConnect()
salesAdapt.GetById(OrderNum)
Dim salesOrderDtl As DataRow =
salesAdapt.SalesOrderData.Tables("OrderDtl").NewRow()'Rows(newRowIndex)
salesOrderDtl("OpenLine")=true
salesOrderDtl("VoidLine")=false
salesOrderDtl("Company")="iei"
salesOrderDtl("OrderNum")="20000"
salesOrderDtl("CustNum")="33"
salesOrderDtl("OrderLine")="1"
salesOrderDtl("Rework")=false
salesOrderDtl("LineType")="PART"
salesOrderDtl("PartNum")="TEST"
salesOrderDtl("LineDesc")="Test"
salesOrderDtl("SellingQuantity")=1
salesOrderDtl("LockQty")=false
salesOrderDtl("MktgCampaignID")="DEFAULT"
salesOrderDtl("MktgEvntSeq")="1"
salesOrderDtl("QuoteNum")="0"
salesOrderDtl("QuoteLine")="0"
salesOrderDtl("Reference")=""
salesAdapt.SalesOrderData.Tables("OrderDtl").Rows.Add(salesOrderDtl)
salesAdapt.Update()
Catch ex As Exception
MessageBox.Show(ex.ToString())
Finally
salesAdapt.Dispose()
End Try
The problem becomes quite apparent that there are about 100 parameters
I'll have to juggle and put defaults in for based on a trace log. Is
there perhaps a way of having the system run it's default processes
based on me saying 'new line, part number, quantity', or is it once I
enter this type of customization I'm on my own and have to do all the
processes manually?
Thanks!
Hello
Does anybody know how can I use customization to prevent entering
data based on some criteria. Let's say I have some Customers that
are in bad standing and based on their CustID I want to prevent
people from entering an order?
We are using Vantage 8.03.304C.
I am experimenting with the code below but it is not working as
expected:
Private Sub OrderHed_BeforeFieldChange(ByVal sender As object, ByVal
args As DataColumnChangeEventArgs) Handles
OrderHed_Column.ColumnChanging
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "CustomerCustID"
If BannedCustomers(args.ProposedValue) Then
MsgBox("You are not
allowed to make Sales Order for Customer: " & args.ProposedValue,
MsgBoxStyle.Exclamation, "Access Denied!")
'Application.Exit
args.ProposedValue = ""
'SalesOrderForm.Close
End if
Case Else
End Select
End Sub
Any idea appreciated.
Why not just put the customer on credit hold.
Patrick Winter
Of abcdefgsaga
Sent: Wednesday, January 03, 2007 10:01 AM
Subject: [Vantage] Order Entry Customization
Hello
expected:
MsgBox("You are not
'Application.Exit
End if
Case Else
End Select
End Sub
Our management sees customer on credit hold and the feature I am
implementing differently.
The characteristic we would like to implement is for customers that were
specifically selected not to do business with.
On the other hand, credit hold is something that is temporary.
Adam Gwizdz
Manager, Corporate IT Systems
Main Tape Company
1 Capital Drive, Suite 101
Cranbury, NJ 08512
(800)718-8273 x332
_____
Of Winter, Patrick
Sent: Wednesday, January 03, 2007 11:20 AM
Subject: RE: [Vantage] Order Entry Customization
Patrick Winter
Behalf
Of abcdefgsaga
Hello
expected:
MsgBox("You are not
'Application.Exit
End if
Case Else
End Select
End Sub
We're on 6.1 and had a similar need where I used a BAM and a VB form to
resolve. On the VB form I gave them 2 text fields to enter whatever
they wish. I then wrote a BAM to fire when a new order header record is
created. If text has been entered then a message is displayed. Maybe
something similar could work for you. Here is the code:
Description: This program reminds order entry when special cusotmer
test exists.
Created By:
Butch Menge
Revision History:
Initial revision
Vantage 6.10
Rev 2.0
Changed program to look at Character09 for text first.
{ud/GlbAlert.i &TableName = "OrderHed"}
FIND Customer WHERE Customer.CustNum = OrderHed.CustNum no-lock.
if (Customer.Character09 <> "") THEN DO:
Message "For " + Customer.Name + " Notice 1: " +
Customer.Character09 + "; Notice 2: " +
Customer.Character10 + "." View-as alert-box information
buttons ok.
END.
Return "Cancel Send":U.
Return.
Butch
Of Gwizdz, Adam
Sent: Wednesday, January 03, 2007 12:52 PM
Adam Gwizdz
Main Tape Company
Cranbury, NJ 08512
(800)718-8273 x332
_____
Behalf
Of Winter, Patrick
Patrick Winter
Behalf
Of abcdefgsaga
Hello
expected:
MsgBox("You are not
'Application.Exit
End if
Case Else
End Select
End Sub
That is a great idea to create A FK View, but this will only display a
warning message.
What I would like to do is not to allow saving entered data.
Adam Gwizdz
Main Tape Company
Cranbury, NJ 08512
(800)718-8273 x332
_____
Of Michael McWilliams
Sent: Wednesday, January 03, 2007 4:30 PM
Subject: [Vantage] Re: Order Entry Customization
What if you Put a field in the customer table to check if you do not
want to sell them use CheckBox01 if not in use. Then Create A FK View
on the Sales order form called Customer. Try the following:
Dim Customer As EpiDataView =
Ctype(oTrans.EpiDataViews ("Customer"),EpiDataView) **THIS SHOULD
COME RIGHT AFTER THE EPIDATAVIEW = ABOVE******
If Customer.dataView(Customer.Row)("CheckBox01") = True Then
MessageBox.Show("This Customer Cannot Be Sold To")
Else
End If
Case Else
End Select
End Sub
"Gwizdz, Adam" <Adam.Gwizdz@...>
were
> Adam Gwizdz
> Main Tape Company
> Cranbury, NJ 08512
> (800)718-8273 x332
> _____
Behalf
> Of Winter, Patrick
> Patrick Winter
<mailto:vantage%
> Behalf
> Of abcdefgsaga
> Hello
> expected:
ByVal
> MsgBox("You are not
> 'Application.Exit
> End if
> Case Else
> End Select
> End Sub
So you want them to not save what they enter, what about if
you did not allow them to enter data in the first place if the
Customer was not OK to sell to?
--- In vantage@yahoogroups.com, "Gwizdz, Adam" <Adam.Gwizdz@...>
display a
> warning message.
> Adam Gwizdz
> Main Tape Company
> Cranbury, NJ 08512
> (800)718-8273 x332
> _____
Behalf
not
View
> Else
> End If
> Case Else
> End Select
> End Sub
> "Gwizdz, Adam" <Adam.Gwizdz@>
that
> were
> > Adam Gwizdz
> > Main Tape Company
> > Cranbury, NJ 08512
> > (800)718-8273 x332
> > _____
> Behalf
> > Of Winter, Patrick
> > Patrick Winter
> <mailto:vantage%
> > Behalf
> > Of abcdefgsaga
> > Hello
> > expected:
> ByVal
> > MsgBox("You are not
> > 'Application.Exit
> > End if
> > Case Else
> > End Select
> > End Sub
How can I stop them from entering data?
Adam Gwizdz
Main Tape Company
Cranbury, NJ 08512
(800)718-8273 x332
_____
Sent: Thursday, January 04, 2007 9:41 AM
display a
> warning message.
> Adam Gwizdz
> Main Tape Company
> Cranbury, NJ 08512
> (800)718-8273 x332
> _____
Behalf
not
View
> Else
> End If
> Case Else
> End Select
> End Sub
that
> were
> > Adam Gwizdz
> > Main Tape Company
> > Cranbury, NJ 08512
> > (800)718-8273 x332
> > _____
<mailto:vantage%
> Behalf
> > Of Winter, Patrick
> > Patrick Winter
> <mailto:vantage%
> > Behalf
> > Of abcdefgsaga
> > Hello
> > expected:
> ByVal
> > MsgBox("You are not
> > 'Application.Exit
> > End if
> > Case Else
> > End Select
> > End Sub
Do not forget to setup the same thing with quote entry (If you use
quote module.) Orders can be entered by using the get from quote.
This will bypass any logic in the order entry screen.
--- In vantage@yahoogroups.com, "Michael McWilliams"
> --- In vantage@yahoogroups.com, "Gwizdz, Adam" <Adam.Gwizdz@>
> display a
> > warning message.
> > Adam Gwizdz
> > Main Tape Company
> > Cranbury, NJ 08512
> > (800)718-8273 x332
> > _____
> Behalf
> not
> View
> > Else
> > End If
> > Case Else
> > End Select
> > End Sub
> that
> > were
> > > Adam Gwizdz
> > > Main Tape Company
> > > Cranbury, NJ 08512
> > > (800)718-8273 x332
> > > _____
> > Behalf
> > > Of Winter, Patrick
> > > Patrick Winter
40yahoogroups.com>
> > <mailto:vantage%
> > > Behalf
> > > Of abcdefgsaga
> > > Hello
entering
that
> > > expected:
> > ByVal
> > > MsgBox("You are not
args.ProposedValue,
> > > 'Application.Exit
> > > End if
> > > Case Else
> > > End Select
> > > End Sub
I'm just starting to experiment with the new BPM module in 8.03. In it there
is a method to look for certain conditions and then to put "Holds" on the
process. You attach actions to object events like SalesOrder.Update or
SalesOrder.GetByID. If a certain condition is true, you're suppose to be able
to send an email, call some custom .Net or 4GL code, or put a process on
"Hold".
Something to consider...
Mark W.
