I’m trying to write a data directive, in-trans method on the OrderDtl table to set the discount of certain part numbers to a discount percentage defined elsewhere in the system.
The intention being, when the add/update a part on the line, it defaults to that specified percent instead of the default at the header. The data directive was also chosen because when they change the header percentage and blow it down to all the lines, I don’t want those lines with the custom discount to change, so it’s being intercepted there.
I have the BPM do some checks and gather data, then ultimately set the following three fields: DiscountPercent, DocDiscount, and DocDspDiscount. Hurray, it works! … Kinda. Turns out it totally hoses up the OrderHed.TrueDiscountPercent and OrderHed.(Doc)TotalDiscount fields–as in it doesn’t recalc these numbers and they eventually get out of sync and it starts to throw errors. Boo! So, next, I did a trace and identified what BO’s are being used (trace below) and executed those in a custom code block. Same result as just setting the fields. Hmmm.
My last attempt was to set the fields using the widgets, then, at the very end, I wrote some code to loop through all of the lines to calculate the total discount, then push that to the OrderHed.(Doc)TotalDiscount field. This successfully updates the field and the OrderHed.TrueDiscountPercent recalcs properly, but, as you can imagine, on large orders, the performance is terrible.
(I did try all of this on a method directive, but it had the same issues plus some poor user experience)
Does anyone have any other suggestions?
<tracePacket>
<businessObject>Erp.Proxy.BO.SalesOrderImpl</businessObject>
<methodName>ChangeDiscountPercent</methodName>
<appServerUri>net.tcp://isiepicor/TEST/</appServerUri>
<returnType>System.Void</returnType>
<localTime>5/13/2019 10:53:40:4825746 AM</localTime>
<threadID>1</threadID>
<executionTime total="82" roundTrip="37" channel="0" bpm="0" other="45" />
<retries>0</retries>
<parameters>
<parameter name="ds" type="Erp.BO.SalesOrderDataSet">
<SalesOrderDataSet xmlns="http://www.epicor.com/Ice/300/BO/SalesOrder/SalesOrder" />
</parameter>
</parameters>
<paramDataSetChanges>
<paramDataSet name="ds" useDataSetNbr="0">
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="DiscountPercent"><![CDATA[13.00]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="UD_SysRevID"><![CDATA[System.Byte[]]]></changedValue>
</paramDataSet>
</paramDataSetChanges>
</tracePacket>
<tracePacket>
<methodName>MasterUpdate</methodName>
<localTime>5/13/2019 10:53:41:8283975 AM</localTime>
<executionTime total="3303" roundTrip="3262" channel="0" bpm="6" other="35" />
<parameters>
<parameter name="lCheckForOrderChangedMsg" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="lcheckForResponse" type="System.Boolean"><![CDATA[True]]></parameter>
<parameter name="cTableName" type="System.String"><![CDATA[OrderDtl]]></parameter>
<parameter name="iCustNum" type="System.Int32"><![CDATA[14722]]></parameter>
<parameter name="iOrderNum" type="System.Int32"><![CDATA[550796]]></parameter>
<parameter name="lweLicensed" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="lContinue" type="System.Boolean"><![CDATA[False]]></parameter>
<parameter name="cResponseMsg" type="System.String"><![CDATA[]]></parameter>
<parameter name="cCreditShipAction" type="System.String"><![CDATA[]]></parameter>
<parameter name="cDisplayMsg" type="System.String"><![CDATA[]]></parameter>
<parameter name="cCompliantMsg" type="System.String"><![CDATA[]]></parameter>
<parameter name="cResponseMsgOrdRel" type="System.String"><![CDATA[]]></parameter>
<parameter name="cAgingMessage" type="System.String"><![CDATA[]]></parameter>
</parameter>
</parameters>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="Discount"><![CDATA[2.99]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="DocDiscount"><![CDATA[2.99]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="OrdBasedPrice"><![CDATA[20.01000]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="DocOrdBasedPrice"><![CDATA[20.01000]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="DocDspDiscount"><![CDATA[2.99]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="DocLessDiscount"><![CDATA[-2.99]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="DocTotalPrice"><![CDATA[20.010]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="DspDiscount"><![CDATA[2.99]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="LessDiscount"><![CDATA[-2.99]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="TotalPrice"><![CDATA[20.01]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="CurrencySwitch"><![CDATA[False]]></changedValue>
<changedValue tableName="OrderDtl" rowState="Modified" rowNum="1" colName="RowMod"><![CDATA[U]]></changedValue>
</paramDataSet>
</tracePacket>
<tracePacket>
<businessObject>Ice.Proxy.BO.ReportMonitorImpl</businessObject>
<methodName>GetRowsKeepIdleTime</methodName>
<returnType>Ice.Tablesets.ReportMonitorTableset</returnType>
<localTime>5/13/2019 10:53:45:4485481 AM</localTime>
<threadID>10</threadID>
<executionTime total="28" roundTrip="8" channel="18" bpm="0" other="2" />
<parameters>
<parameter name="whereClauseSysRptLst" type="System.String"><![CDATA[((PrintDriver='TEXT' AND (AutoAction='PRINT' OR AutoAction='PREVIEW')) OR (PrintDriver='CRYSTAL' AND (AutoAction='PRINT' OR AutoAction='AUTOPRT' OR AutoAction='PREVIEW' OR AutoAction='AUTOPRV')) OR (PrintDriver='EPIFIN' AND (AutoAction='PRINT' OR AutoAction='PREVIEW')) OR (PrintDriver='BARTENDER' AND (AutoAction='AUTOPRT' OR AutoAction='AUTOPRV')) OR (PrintDriver='EDI' AND AutoAction<>'') OR (PrintDriver='SSRS' AND (AutoAction='PREVIEW' OR AutoAction='PRINT') AND LastAction='SSRSREADY')) AND WorkStationID='MK1LAWILLETT 1']]></parameter>
<parameter name="pageSize" type="System.Int32"><![CDATA[0]]></parameter>
<parameter name="absolutePage" type="System.Int32"><![CDATA[0]]></parameter>
<parameter name="morePages" type="System.Boolean"><![CDATA[False]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<businessObject>Ice.Proxy.BO.SysMonitorTasksImpl</businessObject>
<methodName>GetBallonRowsKeepIdleTime</methodName>
<returnType>Ice.Tablesets.SysMonitorTasksTableset</returnType>
<localTime>5/13/2019 10:53:45:4770495 AM</localTime>
<executionTime total="27" roundTrip="10" channel="14" bpm="1" other="2" />
<parameters>
<parameter name="whereClauseSysTask" type="System.String"><![CDATA[history = true and startedon > 05/12/2019]]></parameter>
<parameter name="whereClauseSysTaskLog" type="System.String"><![CDATA[]]></parameter>
<parameter name="absolutePage" type="System.Int32"><![CDATA[1]]></parameter>
</parameters>
</tracePacket>
