Order Allocations in Vantage 6.1
Try running Database Conversion 6430.
As always, make sure you make a good backup before running it though...
Of khambleton500@...
Sent: Tuesday, June 07, 2011 8:45 AM
Subject: [Vantage] Order Allocations in Vantage 6.1
I am perplexed! We have a part number that is showing ?????????? in the
Order Allocation field in the Warehouse tab in Part Tracker. So I
investigated help and that tells me that the allocation is set in Sales
Management, General Operations, Order Allocation. However when I go
there, there is no Order Allocation to select. I check the menu security
(it shows up there) to make sure I have rights, which I do. So I'm
guessing that we do not have some module that triggers the use of Order
Allocation, am I guessing correctly? And if that is the case, how did
this field get the ?????'s ?
Kathy Hambleton
Electron Energy Corporation
VP of Finance
______________________________________________________________________
This email has been scanned by the Connor Manufacturing Services Email
Security System.
For more information please visit http://www.messagelabs.com/email
I am perplexed! We have a part number that is showing ?????????? in the Order Allocation field in the Warehouse tab in Part Tracker. So I investigated help and that tells me that the allocation is set in Sales Management, General Operations, Order Allocation. However when I go there, there is no Order Allocation to select. I check the menu security (it shows up there) to make sure I have rights, which I do. So I'm guessing that we do not have some module that triggers the use of Order Allocation, am I guessing correctly? And if that is the case, how did this field get the ?????'s ?
Kathy Hambleton
VP of Finance
