I wanted to run this by the community because there is so much experience here. I would love to get opinions good or bad (specific if possible) on the following:
We have discrepancies with inventory (raw materials) in our system. This is caused by many factors: Discipline (failure to scan, failure to weigh), material substitutions (using reclaimed material), and slight mfg variances
Discipline in theory should be an easy one to fix - but probably wont be.
Regarding material substitutions - We could add PNâs for all the reclaimed material but there are so many variants that it would be a lot of work and upkeep. Plus, we do not use a fixed amount of reclaimed material.
My thoughts on solving both the mfg variances and use of alternate materials is this:
First, all materials moved into and out of a job (PRESS BIN used a BackFlush) must be weighed. This falls back to discipline but letâs assume it will happen.
Next, before moving any materials into a job the BF/PRESS BIN should be empty. This means that any variances\discrepancies of the job will be solely contained in the PRESS BIN.
At the end of the job - the system assumes certain quantities of materials were used. This is completely irrelevant in our case because it is always off (because the target is always moving). We will remove material on the job and weigh it - and enter this weight into the system which will effectively adjust that PRESS BIN qty for that material to be ACTUAL. If properly executed, this would always ensure the correct quantity of material in the system.
(I want to point out that this would be on a custom screen - not just on the adjustment screen)
CAVEATS:
I realize that all scrap and production has to be entered BEFORE making the weight adjustment.
I realize the user can still misweigh, fatfinger or otherwise screw the value
I realize the thought of an âadjustmentâ makes people cringe - but it will limited to the PRESS BIN
I am sure there is a mob with torches and pitchforks waiting in the wings for me. Iâd love to hear thoughts or suggestions.
Bear in mind a few things before you string me up though:
Our workforce is not very educated
Substituted material is valued at same price as original by accounting
This seems to the lesser of evils when considering the current issues
If the adjustments arenât immediately made, the material goes back into the warehouse and is almost impossible to track
