Use this instead SQL Explorer. Put your info about server and paths. then create the two txt files with commands and another for result . Copy  below 2 lines and create *.bat file. Run and done. Do not forget about COMMIT; at the end in command file after your SQL Queries.
set dlc=\\<your server>\<path>\oe101b
call \\<your server>\<path>\oe101b\bin\sqlexp mfgsys -H <server> -S 8350 -user <user> -password <password> -infile C:\<FILE WITH SQL COMMAND>.txt -outfile C:\<RESULT FILE>.txt -sqlverbose
----- Original Message ----
Sent: Monday, July 28, 2008 10:04:43 AM
Subject: [Vantage] OpenEdge 10.1B - Where's SQL Explorer?
Hi All,
I think I heard before that SQL Explorer is missing from 10.1B but I
installed V8.03.405 on a test server the other day and noticed, first
hand, that it is missing.
Is it hidden somewhere? Is it possible to get it back?
How do you manage ODBC security without it?
I frequently used SQL Explorer to test out SQL statements from the
server and I'm hoping I can get it back.
Joe Rojas
Information Technology Manager
Symmetry Medical New Bedford
P: 508.998.4575
M:508.838.4717
F:508.995.9597
joe.rojas@symmetryn b.com <mailto:joe.rojas@symmetryn b.com>
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Butler, Bruce
Sent: Monday, July 28, 2008 10:12 AM
To: vantage@yahoogroups .com
Subject: RE: [Vantage] Upgrade from 305 to 400 need help!
I got this error a couple of times while upgrading 8.0 to 8.03.400. In
my case I restored the backup database using the OpenEdge 10.0 proenv.
I needed to use the 10.1B proenv to restore the database. Don't know if
this helps.
BB
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of Charlie Wilson
Sent: Friday, July 25, 2008 12:32 PM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
I just got some message about the schema change wouldn't work cuz it
wasn't
a 32 bit codebase or something. I'm blowing it all away and starting
from
scratch if it happens to me again I'll let you all know.
~Charlie
_____
Behalf Of
Edward F. Fox, Jr.
Sent: Friday, July 25, 2008 1:26 PM
LOL. The new instructions are full of missing info like that. They
assume
you know all the little stuff as if you've done it before, but need to
know
if it is your first time.
Edward F. Fox, Jr., CPA
Controller
Maxson Automatic Machinery Company
Phone 401-596-0162 Fax 401-596-1050
www.maxsonautomatic .com
_____
From: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
[mailto:vantage@ yahoogroups <mailto:vantage% 40yahoogroups. com> .com] On
Behalf Of
Charlie Wilson
Sent: Friday, July 25, 2008 1:16 PM
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
I love how they just assume you know this..
~Charlie
_____
Behalf Of
Edward F. Fox, Jr.
Sent: Friday, July 25, 2008 1:09 PM
Run it from the server. It will be in the "Manufacturing by Epicor"
menu.
Controller
_____
Behalf Of
Charlie Wilson
Sent: Friday, July 25, 2008 1:04 PM
I have moved now to the conversion of the database. It says "launch the
schema change 8.03 icon. Where is this said icon.
~Charlie
_____
Behalf Of
Charlie Wilson
Sent: Friday, July 25, 2008 12:25 PM
After spending an hour on the phone with tech support we came to the
conclusion that a domain security policy was causing the issue. After
asking
him what policies may affect this he told me he really couldn't tell me.
So
I asked him to show me where I may look in order to see the policies.
After
taking him to the DC he was unable to produce anything that might cause
this
issue. So I suggested what if we take it off the domain and see if it
works
he thought this was a good idea. So I tried that and the install finally
started. So I really didn't get the issue resolved but I know how to
side
step it when it comes to doing this on the live instance.
~Charlie.
_____
Behalf Of
Charlie Wilson
Sent: Friday, July 25, 2008 10:04 AM
Done still not work even after a restart.
~Charlie
_____
Behalf Of
Charles Carden
Sent: Friday, July 25, 2008 9:11 AM
Open Internet Explorer.
Select Tools/Internet Options
Click the Security Tab
Select Local Intranet and click the Sites button
Uncheck the Automatically detect intranet network
Check all 3 boxes listed
Click the advanced tab
Add your local domain to the list of websites, e.g. thisdomain.com
Behalf Of Charlie Wilson
Sent: Friday, July 25, 2008 7:58 AM
Yes please guide me on how to do this.
~Charlie
_____
.com<mailto: vantage%40yahoog roups.com> [mailto:vantage@ yahoogroups
.com<mailto: vantage%40yahoog roups.com> ]
On Behalf Of
Charles Carden
Sent: Friday, July 25, 2008 8:18 AM
I think you have already tried copying the data locally and ensuring the
program is unblocked. Right?
Is your local (intranet) domain the same as your internet domain? If so
then
the system may not be able to detect your local domain correctly and is
restricting program installation. If that is the case you may have to
open
internet explorer and manually add your domain as an intranet domain. If
you
are unsure how to do this let me know.
Sent: Friday, July 25, 2008 6:43 AM
IE Enhanced Security Uninstalled - Check
Command Prompt - Check
Execute MFGSYS803.exe - Houston we have a problem. "Access Denied"
Any other suggestions?
~Charlie
_____
On Behalf Of
Charles Carden
Sent: Friday, July 25, 2008 7:29 AM
Two more things to try.
1. Open and command prompt window and run the Setup.exe program. Don't
run
the .exe that brings up the install menu just the one that installs the
mfgsys. I don't have the DVD handy so I can't tell you exactly which one
it
is. This will tell you if windows explorer has any software execution
restrictions.
2. Uninstall the Internet Explorer Enhanced Security Configuration
Try number 1 first. If that works you are set to go. If you ever use the
server to access the internet (not advisable) then you most definitely
want
to do number 2 above or it will be a real pain to browse for anything.
Sent: Friday, July 25, 2008 5:59 AM
NO software restriction policies defined. Still not working. Anything
else I
should look for?
_____
On Behalf Of
Charles Carden
Sent: Thursday, July 24, 2008 4:14 PM
I ran into this with one of my machines a few months ago. I am trying to
give you the right answer but I can't remember for sure. It had
something to
do with a local security policy getting set inadvertently. If I remember
right execute the local security policy under control panel. If you have
anything under software restriction policies, just right click Software
Restriction Policies and select Delete Software Restriction Policies. I
believe if you have anything in there it will keep the Vantage setup
from
running because it is being recognized as a 16 bit program.
Sent: Thursday, July 24, 2008 9:20 AM
Subject: [Vantage] Upgrade from 305 to 400 need help!
I'm working on upgrading a test server from 8.03.305 to 8.03.40X i'm am
fallowing the instructions as stated in the manual. But when i go to run
the
file that is the actual server upgrade i get an error that states.
"Windows
can not access the specified, device, path, or file. You may not have
appropriate permissions to access the item." well seeing as that i am a
domain admin i dont believe this is actually a permissions issue. I'm
running this file off the DVD they send you in the mail to do the
upgrade.
Any help any one.
____________ _________ _________ __
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or
proprietary information, and may be used only by the person or entity to
which it is addressed. If the reader of this e-mail is not the intended
recipient or his or her authorized agent, the reader is hereby notified
that
any dissemination, distribution or copying of this e-mail is prohibited.
If
you have received this e-mail in error, please notify the sender by
replying
to this message and delete this e-mail immediately.
No virus found in this incoming message.
Checked by AVG - http://www.avg <http://www.avg <http://www.avg
<http://www.avg <http://www.avg <http://www.avg <http://www.avg
<http://www.avg <http://www.avg <http://www.avg com> com> com> com>
com>
com> com> com> com>
com
Version: 8.0.138 / Virus Database: 270.5.5/1570 - Release Date:
7/24/2008
6:59 AM
DISCLAIMER:
that
If
replying
com> com> com> com>
com
7/24/2008
6:59 AM
DISCLAIMER:
that
If
replying
com> com> com> com>
com
7/24/2008
6:59 AM
DISCLAIMER:
that
If
replying
<http://www.avg <http://www.avg <http://www.avg <http://www.avg com>
com>
com> com> com> com>
com
7/24/2008
6:59 AM
com>
com
7/24/2008
6:59 AM
com
7/24/2008
6:59 AM
Checked by AVG - http://www.avg <http://www.avg <http://www.avg com>
com>
com
7/24/2008
6:59 AM
Checked by AVG - http://www.avg com
7/24/2008
6:59 AM
Hi All,
Joe Rojas
P: 508.998.4575
M:508.838.4717
F:508.995.9597
Of Butler, Bruce
this helps.
BB
Behalf
Of Charlie Wilson
wasn't
from
~Charlie
_____
Behalf Of
Edward F. Fox, Jr.
assume
know
Controller
_____
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Edward F. Fox, Jr.
menu.
Controller
_____
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Charlie Wilson
asking
So
After
this
works
side
~Charlie.
_____
Behalf Of
Charlie Wilson
~Charlie
_____
Behalf Of
Charles Carden
~Charlie
_____
On Behalf Of
Charles Carden
then
open
you
~Charlie
_____
On Behalf Of
Charles Carden
run
it
restrictions.
want
else I
should look for?
_____
On Behalf Of
Charles Carden
something to
from
the
"Windows
upgrade.
Any help any one.
DISCLAIMER:
that
If
replying
com>
com> com> com> com>
com
7/24/2008
6:59 AM
DISCLAIMER:
that
If
replying
com> com> com> com>
com
7/24/2008
6:59 AM
DISCLAIMER:
that
If
replying
com> com> com> com>
com
7/24/2008
6:59 AM
DISCLAIMER:
that
If
replying
com>
com> com> com> com>
com
7/24/2008
6:59 AM
com>
com
7/24/2008
6:59 AM
com
7/24/2008
6:59 AM
com>
com
7/24/2008
6:59 AM
7/24/2008
6:59 AM
