Open Custom Dashboard For Edit Only?
I made a mistake in my custom dashboard code that is resulting in an unbreakable loop as soon as I run the dashboard. This means that I can’t open it to customize it and change the code. What’s the best way to fix the code so I can open the dashboard again? I have to kill Epicor in order to close the dashboard. I already know the offending code, I just can’t change anything due to the loop. Is there a place I can edit the code without using customization?
Thanks!
Nate
I used customization maintenance to open the customization, and export the xml. I edited the xml in notepad++ then reuploaded it with customization maintenance. This was all I needed!
You can also edit the code directly in Customization Maintenance from the Action Menu.
