What I'm trying to do:
-Create a custom BAQ that will be used when a particular report style is selected from the drop down menu when priting (Print > Report Style (drop down menu > CustomBAQ-Crystal) The report will be printed with Crytal Reports.
The problem:
-I'm only getting sample data (two records) to show in the report when I print. I'm trying to add this report to the ARForm definition which is used by the Invoice Tracker.
When I test the BAQ in the BAQ Designer, the data is correct, so it shouldn't be an issue with the BAQ itself.
Any suggestions?
(Epicor 9.05.607b, Crystal Reports 2008)
The problem:
Any suggestions?
