Our production team says that only the lot number and serial number should be changed, not the part number.
In this case, is there a way to handle it?
Since we couldn’t find a way, we are thinking of creating a new job, manufacturing part A into part B, and then manufacturing part B again into part A. But this method is too cumbersome.
Please help. Thank you in advance.
For serials, you can create and reassign them in Serial Number [Maintenance].
It’s not meant to be used much if it all. But it can get you out of a bind.
THE POINT is that you don’t want to end up with 10 EA of something in inventory and 11 (or 9) serial numbers (for the same part) with a status of “Inventory.”
Or qty-adjust one part in and the other part out. We’ve done that many times to “fix” a serial.
Keep in mind that whoever may be auditing your serial number compliance (I’m thinking Aerospace or Medical regulatory specifically) might find this to be… um… less than perfectly acceptable for traceability purposes.
Thank you for your great idea. I confirmed that the lot number can be easily changed in Inventory Transfer. But, I could not change the serial number in “Return Material”. Because “Return Material” is a work on raw material, and I need to change the serial of finished good.
I think I may have gone about it the wrong way. Could you please tell me more about this method?
