Per Progress support:
Windows 2008/R2 has Task Scheduler 2.0 embedded. In Task Scheduler 2.0, Microsoft uses "Credentials management using new security services" as a new feature. The Task Scheduler is now programmed to decrease the priority of any jobs run from Task Scheduler to below normal values for I/O, CPU and Memory operations, so any work scheduled to run are given lower priorities than normal.
To change the priority of a task defined within the Microsoft Task Scheduler 2.0:
1. Export the task (right mouse click the task and save the task as an XML file) .
2. Edit the export XML and modify the Priority value which is defaulted to 7. Set it to 5 which is the normal value.
3. Save the edited XML file.
4. Delete the original task from Task Scheduler.
5. Import the task into Task Scheduler.
HTH,
Calvin Dekker
[cid:image001.jpg@01CE9299.62389510]<http://www.codabears.com/>
630-672-7688 x1484
*Solutions for Epicor users.
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mmcwilliams22
Sent: Monday, August 05, 2013 4:21 PM
Subject: [Vantage] Re: Online Backup hogs all system resources
FYI I did a truncate BI over the weekend and the issue we were having has stopped.
HTH,
Calvin Dekker
630-672-7688 x1484
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "mmcwilliams22" <mmcwilliams22@...<mailto:mmcwilliams22@...>> wrote:
> We had this start happening a few months ago. Every time the backup runs users start getting no servers available. I have an open call to epicor but nothing useful from them yet either. Our DB is only 3Gig
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Ned" <TechnoBabbly@> wrote:
> > How big is your database?
> > Also, the mfgbkup is just calling the probkup command, it's just another
> > script that calls something else.
> > Your script is a bit odd to me, because it doesn't appear to back anything
> > up since that REM is gonna prevent that last line from running regardless of
> > what you are using.
> > Have you run this manually? What happens then?
> > Also, why delete the backup? The command will just overwrite the existing
> > file. I actually suggest people use a script that will take the date or
> > something to the end, that way you end up with more than one actual backup
> > on the system at a time, and you can tell when it's from.
> > -----Original Message-----
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> > adam.whipp
> > Sent: Wednesday, July 31, 2013 2:17 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Online Backup hogs all system resources
> > We are on 8.03.409C on Progress. We use the following script for an online
> > backup every night:
> > echo Running Backup...
> > @echo on
> > d:
> > cd\backup\
> > del backup.1
> > cd\
> > D:\epicor\backup\backup.1
> > D:
> > cd \epicor\oe101b\bin
> > rem probkup online D:\epicor\mfgsys803\db\mfgsys D:\backup\backup.1 mfgbkup
> > As you can see in the script, we have played with both probkup and mfgbkup,
> > and with either one, we have a problem with the system being unusable for
> > about 15 minutes while the backup runs. The backup causes the max number of
> > appservers to spawn and become "busy", which makes the system not able to
> > perform any transactions from a human during that time.
> > Is this normal behavior, or do we have something configured wrong that is
> > allowing the backup to tie up every single appserver? We opened a ticket
> > with Epicor and they were unable to offer much help on this...
> > Thanks for the help!
> > Adam Whipp
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
