Online Back Up
Sophie,
I access the job under the "Backup Jobs" tab and then double-click on the
nightly job that has been set up (BackupExec V8.0). There is then a tab for
"Selections" in which you can open up the various drive and share tress to
work you way down to the epicor\vantage\db (on 4.0 anyway) folder and
dselect certain files. I have deselected the various vantage.xxx files such
as B1, D1, DB etc... about 8 or 9 of them. Don't just deselect the whole
vantage\db folder if there is a subfolder containing your backvan.bat
backup. You want it to go to tape.
BTW - I also copy the backup made by backvan to a drive on another server
and (it gets backed up to tape from there too) because having it on a
different spindle and server helps me sleep better and a restore could be
done a lot faster. I am still pondering restoring automatically every night
to my "test" or sanbox database. If I get VPN working from at home I might
backup to my server there via cable modem and take care of my off-site
storage that way.
I liked the idea posted here about several backvan runs per day and am
considering it for between shifts when activity is lowest. Our backup takes
about 3 minutes for a couple hundred MB so I could sneak it in between the
clocking-out and the clocking-in.
-Todd Caughey
Harvey Vogel Mfg. Co.
Sent: Thursday, December 21, 2000 10:35 AM
To: Vantage egroups list
Subject: [Vantage] RE: Online Back Up
Sophie, we also use Seagate Backup. Go into the area where you have your
scheduled backup job. You should be able to get to it through the "job
monitor" tab. Then, I believe it's under properties for that scheduled job.
Then you will go through and unclick the db file under Vantage so it does
not back it up.
If you have any questions about it, let me know!
Wendy Bowen (Pursche)
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
----- Original Message -----
To: <vantage@egroups.com>
Sent: Thursday, December 21, 2000 11:21 AM
Subject: RE: [Vantage] OnLine Back Up
> With regards to Step 5: Tape BackUp Software, how do I instruct the tape
> back up software to ignore or skip the avtive live db dir? We are using
> Seagate Backup Software.
> Thanks
> Sophie
> > From: Cole, Dave [SMTP:dave@...]
> > Sent: 21 December 2000 13:38
> > To: 'vantage@egroups.com'
> > Sophie,
> > If you use the Epicor supplied BACKVAN.BAT routine there is nothing
> > that can
> > go wrong.
> > I use this in a slightly modified form to backup our database four
> > times a
> > day.
> > Just copy the file from the Vantage directory into a directory
> > something
> > like "C:\Scripts",
> > edit it to point to the correct locations, schedule it to run, and
> > presto,
> > it works just great!!
> > Dave Cole
> > Reeder & Kline
> > From: Jill Seath [mailto:JillSeath@...]
> > Sent: Thursday, December 21, 2000 9:21 AM
> > Subject: [Vantage] OnLine Back Up
> > I would like to start using the on line back up system of Vantage.
> > However I've got an attack of the nerves!!!
> > If something goes wrong while backing up what possibility is there of
> > Vantage being affected?
> > To test the back up and restore would it be better to try it on the
> > Test
> > database rather than the Live?
> > Am I worrying unnecessarily?!
> > Sophie
> > eGroups Sponsor
> > < http://rd.yahoo.com/M=102308.1038796.2731130.908943/D=egroupmail/S=17
<http://rd.yahoo.com/M=102308.1038796.2731130.908943/D=egroupmail/S=17>
> > 000071>
> > 83:N/A=466331/? < http://features.yahoo.com/webceleb/carrey/
<http://features.yahoo.com/webceleb/carrey/> >> Click
> > Here!
> > We no longer allow attachments to files. To access/share Report
> > Files,
> > please go to the following link:
> > < http://www.egroups.com/files/vantage/
<http://www.egroups.com/files/vantage/> >
> > < < http://www.egroups.com/files/vantage/
<http://www.egroups.com/files/vantage/> >>
> > (Note: If this link does not work for you the first time you try it,
> > go to
> > www.egroups.com, login and be sure to save your password, choose My
> > Groups,
> > choose Vantage, then choose Files. If you save the password, the link
> > above
> > will work the next time you try it.)
> > eGroups Sponsor
> > Click Here!
> > 00007183:N/A=466331/? http://features.yahoo.com/webceleb/carrey/
> > Files, please go to the following link:
> > go to www.egroups.com, login and be sure to save your password, choose
> > My Groups, choose Vantage, then choose Files. If you save the
> > password, the link above will work the next time you try it.)
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
eGroups Sponsor
<http://rd.yahoo.com/M=102308.1038796.2731130.908943/D=egroupmail/S=17000071
83:N/A=466330/?http://www.yahoo.com> Click Here!
Sophie, we also use Seagate Backup. Go into the area where you have your scheduled backup job. You should be able to get to it through the "job monitor" tab. Then, I believe it's under properties for that scheduled job. Then you will go through and unclick the db file under Vantage so it does not back it up.
wpursche@...
> Thanks
> Sophie
> > Sophie,
> > that can
> > go wrong.
> > times a
> > day.
> > something
> > like "C:\Scripts",
> > presto,
> > Dave Cole
> > Reeder & Kline
> > Test
> > Sophie
> > eGroups Sponsor
> > 000071>
> > 83:N/A=466331/? <http://features.yahoo.com/webceleb/carrey/>> Click
> > Here!
> > Files,
> > < <http://www.egroups.com/files/vantage/>>
> > go to
> > Groups,
> > above
> > eGroups Sponsor
> > Click Here!
> > 00007183:N/A=466331/?http://features.yahoo.com/webceleb/carrey/>
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
