[Off Topic] Windows-2000-Pro connectivity issue
I am having this same problem on all of the computers we have running
Win2k Pro. All other O/S's are unaffected. Vantage still works fine
on the Win2k machines even though I have the red X. I also get the
message about an error occurring while reconnecting...
I have had some sporadic luck by changing the setting for the net
config server /autodisconnect command on our servers. For info on
this, check out:
http://support.microsoft.com/support/kb/articles/Q138/3/65.asp
It explains what this autodisconnect feature is and how to set it.
I am still having problems, though, so if anybody has an answer to
this one I'd love to hear it.
Lance Ekum
IT Manager
Sentry Equipment Corp
262-567-7256
--- In vantage@y..., Dan Maddox <dmaddox@m...> wrote:
> "Welcome to the club," Todd. I occasionally get this same error on
a WNT4
> PII-266 using a Cisco PCI 340/4800 AirNet radio card. As soon as
you click on
> the apparently red-X'd resource, the connection clears, and all is
> well. This also
> occurrs on a select FEW 95 computers (with radio cards) that hang
off of
> machine
> tools. One click, and everything is well again. I don't recall
having
> seen the problem
> on hard-wired (10/100bT) computers. I don't believe the issue is
2000Pro
> related.
> But, I could be wrong . . . it's happened before.
> Dan Maddox
> Pactiv Corp
> At 04:57 PM 10/2/2001 -0500, you wrote:
> >I'm trying to debug a Windows-2000-Pro connectivity issue and am
looking for
> >some help.
> >Here's what's happening:
> >* Dell Optiplex GX150 - running Windows-2000-Pro
> >* Using my logon which is Network-Administrator
> >* Using logon scripts that connect my machine to about 15 network
drives
> >* From within "Explorer" I can see all of my network drives ...
However,
> >some of the connections are showing a RED X under the drive icon
on the left
> >side of the screen. I can still browse them and copy to them.
The RED-X's
> >float - ie - at times I will only see one connection with a RED-X
while at
> >other times I'll see 5 or 6. Their appears to be no direct
correlation to
> >specific servers.
> >* Also, when a connection shows a RED-X and I'm using software to
try and
> >access files or applications via these connections I will
sometimes get a
> >pop-up box with the following error:
> >*** An error occurred while reconnecting S: to \\server\share
> >*** Microsoft Windows Network: The local device name is already in
use.
> >*** The connection has not been restored.
> >I'm trying to decide if this is a hardware issue with the
integrated
> >3COM-905C NIC or if it is related to Win-2000-Pro.
> >We currently have 4 machines with this configuration all of which
rarely use
> >Vantage. I would like to isolate this behavior before installing
> >Win-2000-Pro on machines that will be using Vantage since I
strongly suspect
> >that what ever is disconnecting these connections will probably
give Vantage
> >the fits.
> >Any ideas would be greatly appreciated.
> >Thanks,
> >Todd Anderson
I'm trying to debug a Windows-2000-Pro connectivity issue and am looking for
some help.
* Using logon scripts that connect my machine to about 15 network drives
* From within "Explorer" I can see all of my network drives ... However,
some of the connections are showing a RED X under the drive icon on the left
side of the screen. I can still browse them and copy to them. The RED-X's
float - ie - at times I will only see one connection with a RED-X while at
other times I'll see 5 or 6. Their appears to be no direct correlation to
specific servers.
* Also, when a connection shows a RED-X and I'm using software to try and
access files or applications via these connections I will sometimes get a
*** Microsoft Windows Network: The local device name is already in use.
I'm trying to decide if this is a hardware issue with the integrated
We currently have 4 machines with this configuration all of which rarely use
Win-2000-Pro on machines that will be using Vantage since I strongly suspect
that what ever is disconnecting these connections will probably give Vantage
the fits.
Todd Anderson
"Welcome to the club," Todd. I occasionally get this same error on a WNT4
PII-266 using a Cisco PCI 340/4800 AirNet radio card. As soon as you click on
well. This also
occurrs on a select FEW 95 computers (with radio cards) that hang off of
machine
tools. One click, and everything is well again. I don't recall having
seen the problem
on hard-wired (10/100bT) computers. I don't believe the issue is 2000Pro
related.
Dan Maddox
Pactiv Corp
>some help.
>specific servers.
>the fits.
>Thanks,
>Todd Anderson
Todd,
I think the Red X's are a W2k thing. But to keep your network connection
okay - check this. In Control Panel
Network & Dial-up Connections
Properties - button (Local Area Connection status)
On the Local Area Connection Properties select the Configure button
under your network card
On the Power Management Tab
Take the Check Mark out of "Allow the computer to turn off
this device to save power"
Hope this helps.
Nancy Dunn
Winco Ind.
Sent: Tuesday, October 02, 2001 5:57 PM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] [Off Topic] Windows-2000-Pro connectivity issue
some help.
specific servers.
the fits.
Todd Anderson
