[off topic] Day Light Saving Time
Doh! Forgot to mention... IIRC, after you patch, you need to go into
the timezones control panel and:
Select a different zone ; apply ; reset to correct zone ; apply
for the change to take effect.
wayne wrote:
> This site has a free utility. One click, and it installs the patches
> (including some recent non-USA ones) or tells you if everything is up to
> date:
> Windows NT/2000/XP/2003 Daylight Saving Time Fix:
> http://www.intelliadmin.com/Downloads.htm
> -Wayne
Good Morning.
When I came in this morning my clock on the Windows 2000 Server (which runs
Vantage) keep changing its time to go back one hour. I change correct the
time manually but it keeps reverting back to one hour late.
Does anyone know how to fix this? I thought there was a patch fix for this
from Windows but I can not find it.
Any suggestions would be great. – Every ½ I am fixing our time.
Thank you,
Dina Hieber
Vamco International, Inc.
555 Epsilon Drive, Pittsburgh, PA 15238
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
Website; www.vamcointernational.com
This e-mail message and any files transmitted with it are confidential and
are intended for the sole use of the intended recipient(s). Any unauthorized
use or disclosure is prohibited. Any opinions expressed in the email are
those of the individual and not necessarily the company. If you are not the
intended recipient, please contact the sender by reply email and destroy all
copies of the original message.
Dina,
The fix for that is called TZEDIT and used to be available on Microsoft's site. You can also uncheck your "Automatically adjust for Daylight Savings Time"
on your server to stop it from changing the time back on you until you get the fix installed.
HTH,
Julie
Mercury Minnesota Inc.
----- Original Message -----
Sent: Monday, October 27, 2008 8:40 AM
Subject: [Vantage] [off topic] Day Light Saving Time
Good Morning.
Any suggestions would be great. - Every ½ I am fixing our time.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
Julie,
I did uncheck that box and it did not make a difference. In the past that
is what I did but some how it was checked back and now the time will not
stay correct.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
_____
Julie Lehmann
Sent: Monday, October 27, 2008 9:47 AM
Subject: {Disarmed} Re: [Vantage] [off topic] Day Light Saving Time
Dina,
Time"
the fix installed.
HTH,
Julie
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Good Morning.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@vamcointern <mailto:dhieber%40vamcointernational.com>
ational.com
There is, unfortunately, no "patch" for Windows2000 (that I know of), but you could use the TZEdit program, which I only just learned of from Julie's post.
The way Windows handles time is that it sets the clock to GMT, then calculates the offset and displays the adjusted time. So, when you set your server's time manually, you are actually changing the internal clock from GMT to GMT +1. Then, because you're in PA, your computer subtracts 5 (EST per pre-2007 DST dates) instead of 4 (EDT per DST2007).
If you have your server set to sync its time with another computer on your network (or with the Internet time servers), it sets the internal clock back to GMT. Since Windows2000 doesn't know about the DST2007 date change, it adjusts back to GMT -5.
For the next week, I think you have two options: 1) Change the time-zone from GMT-5 to GMT-4, then change it back again next week; 2) turn off sync'ing of time, which may be difficult if it's set per group-policy. Or, try out the TZEdit program, available here:
http://support.microsoft.com/kb/914387
--Ari
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of dhieber
Sent: Monday, October 27, 2008 8:41 AM
Good Morning.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@... <mailto:dhieber%40vamcointernational.com>
Dina,
Is it possible the server is picking up the time from another computer with the wrong time. I have my servers synch time with one specific server - just a thought.
The Microsoft patch does work though.
Nancy
Sent: Monday, October 27, 2008 9:52 AM
Subject: RE: {Disarmed} Re: [Vantage] [off topic] Day Light Saving Time
Julie,
I did uncheck that box and it did not make a difference. In the past that is what I did but some how it was checked back and now the time will not stay correct.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
This e-mail message and any files transmitted with it are confidential and are intended for the sole use of the intended recipient(s). Any unauthorized use or disclosure is prohibited. Any opinions expressed in the email are those of the individual and not necessarily the company. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
_____
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf Of Julie Lehmann
Dina,
HTH,
Julie
Good Morning.
Vantage) keep changing its time to go back one hour. I change correct the time manually but it keeps reverting back to one hour late.
Does anyone know how to fix this? I thought there was a patch fix for this from Windows but I can not find it.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
ational.com
Nancy and too all.
We used the Microsoft patch - so we should be okay. At first I did not
think it was working because Vantage time was wrong. But I stopped and
restarted progress service and all for now seems okay. I am crossing my
fingers.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
Dunn, Nancy
Sent: Monday, October 27, 2008 11:38 AM
To: 'vantage@yahoogroups.com'
Dina,
just a thought.
Nancy
dhieber
Julie,
correct.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
_____
Dina,
Time"
the fix installed.
HTH,
Julie
Good Morning.
Thank you,
Dina Hieber
Tel: (412) 963-7100
Fax: (412) 963-9511
ational.com
date:
-Wayne
