So we are getting an error in out Pilot system, that we aren’t getting in our production system. I copied the error below. I think it has to do with a UD field issue, but I’m not sure where to look. We created a UD field in Pilot once to try out something with an updateable dashboard, but it didn’t work out so we didn’t replicate in production. Since then, we’ve copied over production to pilot, and now we are getting this error in pilot. It looks like the UD field map still exists for some reason. That’s about where we get stuck because you can’t delete those mappings. We will probably copy over again and see if the error goes away, (because maybe it’s related to me messing around in the system) but if anyone know what this error is and where to look around to fix it, that would be helpful.
Server Side Exception
An error occurred while executing the command definition. See the inner exception for details.
Error Detail
Description: An error occurred while executing the command definition. See the inner exception for details.
Inner Exception: Invalid object name 'Erp.JobMtl_UD'.
Program: System.Data.Entity.dll
Method: ExecuteStoreCommands
Original Exception Type: EntityCommandExecutionException
Framework Method: <Compile>b__14a
Framework Line Number: 0
Framework Column Number: 0
Framework Source: <Compile>b__14a at offset 53 in file:line:column <filename unknown>:0:0
Server Trace Stack: at System.Data.EntityClient.EntityCommandDefinition.ExecuteStoreCommands(EntityCommand entityCommand, CommandBehavior behavior)
at System.Data.Objects.Internal.ObjectQueryExecutionPlan.Execute[TResultType](ObjectContext context, ObjectParameterCollection parameterValues)
at System.Data.Objects.ObjectQuery`1.GetResults(Nullable`1 forMergeOption)
at System.Data.Objects.ObjectQuery`1.System.Collections.Generic.IEnumerable<T>.GetEnumerator()
at System.Linq.Enumerable.Single[TSource](IEnumerable`1 source)
at System.Data.Objects.CompiledQuery.ExecuteQuery[TResult](ObjectContext context, Object[] parameterValues)
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass14b`6.<>c__DisplayClass14e.<Compile>b__14a(Func`6 query)
at Epicor.Data.DBExpressionCompiler.InvokeSingle[TContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext context, Func`2 getDataCacheKey, Func`2 compileQuery, Func`2 executeQuery)
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass14b`6.<Compile>b__147(TContext context, TArg1 arg1, TArg2 arg2, TArg3 arg3, TArg4 arg4)
at Erp.Services.BO.PartSvc.ExistsJobMtl(String company, Boolean jobComplete, Boolean issuedComplete, String partNum)
at Erp.Services.BO.PartSvc.setEnableUOMClass()
at Erp.Services.BO.PartSvc.PartAfterGetRows()
at Erp.Services.BO.PartSvc.OnRowEvent(DataTableEventType type, String tableName, IceRow row)
at Ice.TablesetBound`3.<>c__DisplayClass25.<InnerGetByID>b__1f()
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action)
at Ice.TablesetBound`3.InnerGetByID(IceDataContext context, Int32 pageSize, Int32 absolutePage, Boolean& morePages, TFullTableset tableset, IEnumerable`1 queryParameters)
at Erp.Services.BO.PartSvc.GetByID(String partNum)
at Erp.Services.BO.PartSvcFacade.GetByID(String partNum)
at SyncInvokeGetByID(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func)
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Inner Trace:
: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.PartImpl.GetByID(String partNum)
at Erp.Adapters.PartAdapter.OnGetByID(String ID)
at Ice.Lib.Framework.EpiBaseAdapter.GetByID(String stringId)
at Erp.UI.App.PartRevCheckoutEntry.Transaction.ValidatePart(String partNum)
