Paul,
I had a similar problem when I was running Promon and stop the database
using the MMC console. If you are using Promon, I would recommend to exit
Promon and stop the database with the MMC console. Also, the vantage.lk file
is the one generated when the database is running. You might need to go to
the folder and deleted prior to start up the database. If this file is in
the folder and you are trying to start up the database, you will get this
error.
Hope it helps!
Mario Aguirre
Lakin General
Sent: Thursday, February 12, 2004 7:39 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] Odd db start up error
I have successfully built a few test servers with Vantage 5.2, however, on
the latest one I built, I am getting an odd db start up error:
Error in database startup. (JUNMsg030)
Error in startup of database localhost:20931:Epic52.
Message:
16:35:28 BROKER :
** This process terminated with exit code 1. (8619) (JUNMsg024)
I didn't do anything different, and the db ran fine for a day or so. After
I shut it down, and booted back up the above error message is the result.
I have checked the Answerbook, but their lone solution didn't work for me.
Even the Progress sources hardly ever mention this error.
Has anyone seen it before, or how do I make it go away?
Paul
Sent: Thursday, February 12, 2004 8:08 AM
Subject: Re: [Vantage] Steel prices causing price changes
We are facing the same issue. We need an effective solution. I am sorry
for my ignorance, but what is ground control?
Any help in this matter would be very much appreciated.
Zoran Zarkovic
Computer Engineering Specialist
E.J. Basler Co.
mansfield1024 <johnm@...> wrote:
Hi everyone,
We are facing steel price changes and surcharges.
We have 1000's of parts on 1000's of orders on the books.
We would like to adjust our prices on these orders.
Is ground control the answer?
Does ground control do the mouse clicks needed to navigate the screen?
Any help would be appreciated.
Thanks in advance,
John Mansfield
General Sheet Metal
Yahoo! Groups Links
To visit your group on the web, go to:
<http://groups.yahoo.com/group/vantage/>
To unsubscribe from this group, send an email to:
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online
Yahoo! Groups Links
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
error.
Hope it helps!
Mario Aguirre
Lakin General
Message:
16:35:28 BROKER :
Paul
Zoran Zarkovic
E.J. Basler Co.
Hi everyone,
Thanks in advance,
John Mansfield
General Sheet Metal
Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Groups Links
_____
Yahoo! Groups Links
