Correction to the max length. I meant to write it is well over 1000
not 2000. I believe the max SQL length is 2048. Set you SQL length
to 2048. If you have fields with more characters than 2048 your out
of luck. -200112 error is a known limitation. However I don't think
you will find Progress jumping on fixing this problem since large
character fields are problems with my applications and ODBC drivers.
It's an acceptable limitation to the developers.
--- In vantage@y..., "Peter" <peter.paasch@a...> wrote:
> What did you set your SQL width to in Data Admin? If you set it
> lower than the amount of data you are trying to access you will
> recieve a max length error. Vantage tech support is miss guided in
> the idea that shortening up the SQL lenth fixes all woes. They
> should read the Progress ODBC guide. Run an ODBC Trace by going to
> the ODBC admin and clicking the trace tab. Start a new trace and
> look at the log file after you try to access the table through MS
> Acsess. It will give you a specific function call that failed.
Post
> the error or email me the file ODBC trace file. Progress ODBC does
> have a Limit on the length but it is well over 2000. This might
not
> solve your problem but it will help to eliminate a the Progress
ODBC
> driver as a possible cause.
> --- In vantage@y..., "lance02" <lance02@y...> wrote:
> > I am having 2 problems when using my ODBC connection (Merant 3.60
> for
> > Progress 9.1C driver). This problems have just started happening
> > recently. We upgraded from Vantage 5.0 to 5.1 on March 1.
> Problems
> > didn't start occurring until (1) mid-March and (2) two days ago.
> > Problem (1) When I try to run a query in MSAccess 2000 I get a
> > Merant ODBC--call failed error saying my column InvcDtl.LineDesc
> has
> > exceeded its max length (#-210012). This is a memo field with
1000
> > character in Vantage. I try to truncate the field to 50
> characters,
> > but no luck (on a test db). Vantage tech support tells me that
the
> > problem may be that I have part descriptions greater than 2000
> > characters (I do, but we need them, and I can't yet find these
> parts
> > duplicated in the InvcDtl.LineDesc field anyway). Any ideas??
Oh,
> > and it started happening about the time I installed the latest
> > Progress patch P91C19. There may or may not be a correlation.
> > Problem (2) This just started happening, the day after I
installed
> > the Vantage 5.10.120 patch. Now, when I bring data into Access
> 2000
> > via a linked table, it will work when I first bring it in just
> fine.
> > But if I close Access and the re-open it and open the database I
> > created earlier, I get the error ODBC call failed -- Merant
Access
> > denied (Authorisation failed)(7512)(#-20228). If I try to add
> > another linked table, it will let me add it but not view it or
run
> > queries on it. Again, if I were to start a brand new Access
> > database, as long as I don't close Access I am able to do
> everything
> > just fine. Any idea on this one?
> > Thanks for the help.
> > Lance Ekum
> > IT Manager
> > Sentry Equipment Corp
