ODBC - Crystal reports 8 ,8.5 - Vantage 8.03
Hi
No you are kind of right, but you can get realy time by running the report from a menu item (but that again I suppose would only give you a snapshot).
The closest thing you can get to a snapshot this way is to with a BAQ export on a scheduled task every minute.
You can teach me something now - if you create a report to odbc does it automatically update in real time without having to refresh?
Sent: Friday, 18 May 2012, 15:30
Subject: [Vantage] Re: ODBC - Crystal reports 8 ,8.5 - Vantage 8.03
Â
Thanks Chris,
I think I understand what you are saying and I tried it. Correct me if am wrong but does this not just create a "snapshot" in time of the data at the time you ran the report through vantage that created this XML file. What if we want "realtime" reporting of the data. I don't want to have to "regenerate" an XML file through Vantage and then update the Crystal Report from there? Am I missing something?
Mike..
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...> wrote:
> Hi Mike
> The topic is huge, and I dont have took much time today so I will go over it hi-level.
> When Epicor prints to a crystal document, it creates an xml which is then pushed into the .rpt and runtime displays it as a preview or prints it.
> Typically these are stored in ...\EpicorData\Reports\[user name]
> So if you were to print an eg Quote to screen and locate your folder, you should see the xml it creates.
> You can then add additional fields to the canned reports.
> You can also create BAQs and Dashboards then create fully custom crystal reports from data stored within the dashboards (or if you dont want to create a dashboard you can create a BAQ Report (which is literally a print screen with filters/criteria)).
> You can then add the dashboard or BAQ report to a menu item for anyone to run (depending on security levels required).
> Sorry to be brief.
> I can give you more info on specific areas if you need it.
> From: flexial_ma <mike.abell@...>
> Sent: Friday, 18 May 2012, 14:48
> ÂÂ
> Chris,
> Could you give me an example of what you mean by "XMLs which Epicor creates when it prints" and how you "use" that in CR. This is GOOD information Chris and I really appreciate it.
> Mike...
> --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@> wrote:
> > I have crystal developer or whatever it is called installed on my PC and create all the reports on it using XMLs which Epicor creates when it prints.
> > Never had to touch odbc and have all the reports we need and more.
> > You can then make menu items in Epicor to run the reports if you want to (using crystal run time).
> > From: flexial_ma <mike.abell@>
> > Sent: Friday, 18 May 2012, 14:39
> > ÂÂÂ
> > Thanks for the reply Chris,
> > Acutally, I am a developer and I am used to creating CR in my apps which "connect" to external data sources (in this case Vantage) but I usually create the Crystal Report first and import it into my app. The CR 11 app that I think Epicor provides is not installed on any of our clients (including mine) so Vantage will not let me create a Crystal Report from "within" it. I think only the "runtime" engine is installed.
> > Mike..
> > > I find you can pretty much do everything you need within Epicor (link tables etc) then connect to Crystal to make it look 'pretty' if you need to.
> > > What specifically cant you do in Epicor that makes you want to do everything externally?
> > > Sent: Friday, 18 May 2012, 14:28
> > > Subject: [Vantage] ODBC - Crystal reports 8 ,8.5 - Vantage 8.03
> > > ÂÂÂÂ
> > > Guys,
> > > I am very new to Vantage and I came from a company that used CR exclusively with their ERP system for designing reports outside of the actual software. I am very familiar with CR versions 8 to 11 and I have the OpenEdge ODBC driver installed on my PC connected to our Vantage Progress database. Since no one else here uses Crystal and Vantage outside of the software, I just wanted to know if there are any downsides to using Crystal with the OpenEdge driver and specifically are their any issues with an older version of CR(like 8,8.5) that I should know about. I've been indirectly told here I shouldn't connect to the Vantage database this way but I wanted expert opinions. Thanks in advance for any help!
> > > Mike Abell
Guys,
Mike Abell
Â
Guys,
Mike Abell
Mike..
> ÂÂ
> Guys,
> Mike Abell
Â
Mike..
> ÂÂ
> Guys,
> Mike Abell
Chris,
Mike...
> ÂÂ
> Mike..
> > ÂÂÂ
> > Guys,
> > Mike Abell
Hi Mike
Sorry to be brief.
Â
Chris,
Mike...
> ÂÂ
> Mike..
> > ÂÂÂ
> > Guys,
> > Mike Abell
Thanks Chris,
Mike..
> Hi Mike
> Sorry to be brief.
> ÂÂ
> Chris,
> Mike...
> > ÂÂÂ
> > Mike..
> > > ÂÂÂÂ
> > > Guys,
> > > Mike Abell
Mike, I cannot post these publicly, but these textbooks attached should help
your initial endeavor into thisÂ….
In a nutshell:
1. Create a BAQ in Vantage (your query)
2. Make a BAQ Report in Vantage via BAQ Report Designer (basically binds
that BAQ to a "report UI" that allows you to hang this "report" off a menuÂ…
also provides you with the ability to set options, filters, date ranges
here)
2a) hang your BAQ Report off a Vantage Menu via Menu Maint
3. Run your BAQ ReportÂ…. it dumps the result set from Step1 into an XML
formatted dataset under \\yourserver\epicor\mfgsysdata\reports\user
<file:///\\yourserver\epicor\mfgsysdata\reports\user>
4. Grab that XML and use it as your data source in your CR.
5. Build your CR on that XML result setÂ… it's your datasource
6. Once you get it formatted, place the CR .rpt file in
<file:///\\yourserver\epicor\server\reports\XXX_CustomReports>
\\yourserver\epicor\server\reports\XXX_CustomReports where XXX is your
company's initials or something. NEVERÂ…. EVERÂ….. NEVER store your customized
.rpt files in the \server\reports folder as they can get overwritten during
Vantage updates/upgrades/patches. :-)
The benefit to doing it this long convoluted way? It nicely integrated into
the Epicor UI. You can also pass options and date ranges from the BAQ
Report so that your result set is small. The XML only contains the results
you need for your report (again, filtered/optioned/date ranged by the user).
When using ODBC it pulls ALL records to the client and then performs the
filtering, etc on the client (one exception to this is using SQL Epressions
in CR; only if you have SQL as your db). So that's a lot of data in some
instances that's coming across the network that is waste.
There are times when ODBC is your only option. Perhaps the query is too
complicated. For me, I sometimes create complex SQL views that have queries
that would be impossible to recreate in a BAQ. So then I'll use ODBC and
hit the SQL view and may also pass over SQL Expressions to SQL from CR to
limit my resultset coming across the wire.
HTH
flexial_ma
Sent: Friday, May 18, 2012 9:49 AM
Chris,
Mike...
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Chris
> Â
> Mike..
> > ÂÂ
> > Guys,
> > Mike Abell
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2176 / Virus Database: 2425/5007 - Release Date: 05/18/12
