ODBC - Client: 64bit / Server 64bit
What is the issue you're having? Can't create ODBC Reports?
Regards,
Jen
Of effgroups@...
Sent: Friday, June 24, 2011 5:54 PM
Subject: Re: [Vantage] Re: ODBC - Client: 64bit / Server 64bit
The reason I pointed you to that message is because you mentioned the
issue with win 7 64bit and I had there some solution for that.
Ephraim Feldman
Programmer / Analyst
Axis Lighting
<mailto:havrilla%40gmail.com> >
Sender: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Date: Fri, 24 Jun 2011 11:40:20
To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Subject: [Vantage] Re: ODBC - Client: 64bit / Server 64bit
Ephraim,
You're running 10.1C/9.04...I was asking about 10.1B/8.03 on my original
post.
Regards,
Jeremey
effgroups@... wrote:
> I answered it today in my other message.
> Ephraim Feldman
> Axis Lighting
> From: "Alex Fiedler" <alex@...>
> Date: Thu, 23 Jun 2011 01:00:19
> I am interested that you are running 10.1b on 64-bit 2008R2. Did you
not get an installation error relating to the Progress Explorer tool?
> Are you actually able to run the database and application servers
without errors?
"jeremeyhavrilla" <havrilla@> wrote:
> > Hey Group,
> > Is anyone successfully running ODBC to Progress 10.1b/Vantage 8.03
server that's running 2008R2 (64bit)?
> > Specifically I'm having difficulties connecting with Win 7 64bit to
Progress 10.1b on 2008R2 server. I know Windows 7 64bit client will work
to 32bit server but is anyone working with 64/64?
> > Thanks!
> > Jeremey
Hey Group,
Is anyone successfully running ODBC to Progress 10.1b/Vantage 8.03 server that's running 2008R2 (64bit)?
Specifically I'm having difficulties connecting with Win 7 64bit to Progress 10.1b on 2008R2 server. I know Windows 7 64bit client will work to 32bit server but is anyone working with 64/64?
Thanks!
Jeremey
We're on E9, Progress 10.2A, but I've got it working 64/64. What are your specific issues?
Sean B
--- In vantage@yahoogroups.com, "jeremeyhavrilla" <havrilla@...> wrote:
> Hey Group,
> Thanks!
> Jeremey
I am interested that you are running 10.1b on 64-bit 2008R2. Did you not get an installation error relating to the Progress Explorer tool?
Are you actually able to run the database and application servers without errors?
> Hey Group,
> Thanks!
> Jeremey
Ephraim Feldman
Axis Lighting
To: <vantage@yahoogroups.com>
> Hey Group,
> Thanks!
> Jeremey
Ephraim,
You're running 10.1C/9.04...I was asking about 10.1B/8.03 on my original post.
Regards,
Jeremey
> Ephraim Feldman
> Axis Lighting
> --- In vantage@yahoogroups.com, "jeremeyhavrilla" <havrilla@> wrote:
> > Hey Group,
> > Thanks!
> > Jeremey
The reason I pointed you to that message is because you mentioned the issue with win 7 64bit and I had there some solution for that.
Ephraim Feldman
Axis Lighting
Ephraim,
Regards,
Jeremey
> Ephraim Feldman
> Axis Lighting
> > Hey Group,
> > Thanks!
> > Jeremey
