Obtain Comports
I am trying to obtain the available/defined comports using this code but am getting a compiler error stating
The type or namespace name 'ManagementObjectSearcher' does not exist in the namespace 'System.Management' (are you missing an assembly reference?)
Do you guys have any ideas on how I can get this to compile?
using (var searcher = new System.Management.ManagementObjectSearcher("SELECT * FROM Win32_PnPEntity WHERE Caption like '%(COM%'"))
                var portnames = SerialPort.GetPortNames();
                var ports = searcher.Get().Cast<ManagementBaseObject>().ToList().Select(p => p["Caption"].ToString());
                var portList = portnames.Select(n => n + " - " + ports.FirstOrDefault(s => s.Contains(n))).ToList();
                for( int i=0; i < portList.Count; i++)
                    var s = portList[i];
                    if (s.Contains("Prolific"))
                        strComPort = portnames[i];
I used this class in Vantage
and
Thank you Mark.
That file will be here:
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\System.Management\v4Xsomething\System.Management.dll
Copy it into your client folder to reference.
Now that being said, what are you doing?
trying to reliably get comport my device is connected to.
Thank you. This is exactly what I needed and is working great.
Truth What GIF by Britannia
Nothing. I am connecting a scale to the Epicor computer and it communicates through a comport. I just want to discover it on load.
Ah ha!
You LIE!
You are connecting a scale!
