Object not set to instance of an object. Can't delete Child UD.U
Yeah I did that and it worked fine but I am in 702 must have been fixed there.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@…
http://www.josecgomez.com
     Â
On Fri, Sep 20, 2013 at 11:13 AM, Marc Livingston <livingstonmarc86@...> wrote:
Â
<div>
  <p></p><div style="font-size:12pt;font-family:times new roman, new york, times, serif;">The customization I added does not have the added code.<br><br>To get the error, navigate to the tab &#39;Unit Information&#39; under the main customer tab. Add 2 new records and then try selecting one of the records in the grid and deleting it. <br>
To: Vantage <vantage@yahoogroups.com>
Sent: Friday, September 20, 2013 10:00 AM
Subject: Re: [Vantage] RE: Object not set to instance of an object. Can't delete Child UD.UltraGrid
Â
<div>
  <div dir="ltr"><div style="font-family:verdana, sans-serif;font-size:small;">I loaded your customization in my environment and had no problems. Do you have visual studio 2010? If so you can connect it to your customization and step through the code to identify the culplit line once we have that infromation we might be able to write something around it.</div>
Jose C Gomez
Software Engineer
E: jose@...
     Â
On Fri, Sep 20, 2013 at 9:47 AM, Marc Livingston <livingstonmarc86@...> wrote:
Â
<div>
  <div style="font-size:12pt;font-family:times new roman, new york, times, serif;">Alright I added it to the 9.0 files. We are on version 9.05.701. Error comes when selecting any record in the grid on the added sheet and trying to delete.<br>
Sent: Friday, September 20, 2013 8:02 AM
Â
<div>
  <div dir="ltr"><div style="font-family:verdana, sans-serif;font-size:small;">Upload or put your original customization here and let me take a look at it (What version?)</div></div><div>
Jose C Gomez
Software Engineer
E: jose@...
     Â
On Fri, Sep 20, 2013 at 8:52 AM, <livingstonmarc86@...> wrote:
Â
<div>
  <div>This was Epicor&#39;s response when they could not get it to work either:</div><div>
I added the code work around to the Customization you sent me and when I did a Test Code, I received several Compile errors, complaining about duplicate code.
Â
It appears the work around Development provide was for that Customer's specific Customization and conflicts with the Customization you sent me.
Â
I informed my Team Lead and she reminded me there are no programmers in Tech Support and suggested contacting our Custom Solutions Group (CSG).
--- In vantage@yahoogroups.com, <livingstonmarc86@...> wrote:
I was trying to work with support with the above issue, but they only had a sample for the Plant form which I was not able to transfer to the Customer form.
This is the answer book they sent to me:
PROBLEM DESCRIPTION: In Plant Maintenance, a UD table was added to the form. You can create new UD records and save those records with no issue. However, if you have 2 or more UD records loaded in the form and you delete a UD record, the following error is received:
Â
Object reference not set to an instance of an object.
Â
PROGRAM ID:Â Customization
Â
EXPECTED BEHAVIOR:Â No error should be received.
Â
Â
Development linked the issue I reported to an existing Open (not yet resolved) SCR 82779 that is being used to track all Child UD tables issues. Development also provided me with a Work Around (included after my Signature Line and uses the attached Sample Customization for Plant Maintenance - you will need to modify the work around code for your needs).
***Note:Â See attached customization example step 1:
<Tools><Wizards> Reference Adapater/BLAssebmlies Wizard Select Plant Adapter and click "Finish"
Â
Â
Step 2:
Declare a class level varialbe
Â
private [static] DataTable _dtUD05;
Â
Step 3:
Clean up DataTable object in DestroyCustomCode()
Â
_dtUD05.Clear();
_dtUD05 = null;
Â
Â
Step 4:
Initialize _udUD05 in InitializeUD05Adapter() An add the DataTable to the Adapter DataSet
Â
_dtUD05 = _edvUD05.dataView.Table.Clone(); ((ProjectAdapter)oTrans_plantAdapter).PlantData.Tables.Add(_dtUD05);
Â
Â
Step 5:
Add dummy UD38 Table to Adapters DataSet in DeleteUD05Record() method if (!((ProjectAdapter)oTrans_plantAdapter).PlantData.Tables.Contains(_dtUD05.TableName))
Â
Â
Step 6:
In the Form Event Wizard Tab add a "BeforeAdapterMethod" event handler and add the following code:
Â
if (((PlantAdapter)oTrans_plantAdapter).PlantData.Tables.Contains(_dtUD38.TableName))
     ((PlantAdapter)oTrans_plantAdapter).PlantData.Tables.Remove(_dtUD38);
Â
I have ran into issues trying to edit this for the customer form, can anyone help with this?
 Below is my script for my customization, sorry for the long message:
// Custom code for CustomerEntryForm
// Created: 8/7/2013 2:50:41 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.Searches;
Â
public class Script
Â
     private UD01Adapter _ud01Adapter;
     private EpiDataView _edvCustomer;
     private EpiDataView _edvUD01;
     private string _Key1UD01;
     private string _Key2UD01;
     private string _Key3UD01;
     private string _Key4UD01;
     private string _Key5UD01;
     private DataView Customer_DataView;
Â
Â
Â
           this._Key1UD01 = string.Empty;
           this._Key2UD01 = string.Empty;
           this._Key3UD01 = string.Empty;
           this._Key4UD01 = string.Empty;
           this._Key5UD01 = string.Empty;
           this.baseToolbarsManager.ToolClick += new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClickForUD01);
           this.CustomerEntryForm.BeforeToolClick += new Epicor.Mfg.UI.FrameWork.BeforeToolClickEventHandler(this.CustomerEntryForm_BeforeToolClickForUD01);
           this.Customer_Row.EpiRowChanged += new EpiRowChanged(this.Customer_AfterRowChangeForUD01);
           this.Customer_DataView = this.Customer_Row.dataView;
           this.Customer_DataView.ListChanged += new ListChangedEventHandler(this.Customer_DataView_ListChangedForUD01);
Â
Â
           InitializeUD01Adapter();
           this.epiUltraGridC1.KeyDown += new System.Windows.Forms.KeyEventHandler(this.epiUltraGridC1_KeyDown);
           this.epiUltraGridC1.BeforeRowsDeleted += new Infragistics.Win.UltraWinGrid.BeforeRowsDeletedEventHandler(this.epiUltraGridC1_BeforeRowsDeleted);
           this.epiUltraGridC1.BeforeRowInsert += new Infragistics.Win.UltraWinGrid.BeforeRowInsertEventHandler(this.epiUltraGridC1_BeforeRowInsert);
Â
Â
           if ((this._ud01Adapter != null))
                 this._ud01Adapter.Dispose();
                 this._ud01Adapter = null;
           this._edvUD01 = null;
           this._edvCustomer = null;
           this._Key1UD01 = null;
           this._Key2UD01 = null;
           this._Key3UD01 = null;
           this._Key4UD01 = null;
           this._Key5UD01 = null;
           this.baseToolbarsManager.ToolClick -= new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClickForUD01);
           this.CustomerEntryForm.BeforeToolClick -= new Epicor.Mfg.UI.FrameWork.BeforeToolClickEventHandler(this.CustomerEntryForm_BeforeToolClickForUD01);
           this.Customer_Row.EpiRowChanged -= new EpiRowChanged(this.Customer_AfterRowChangeForUD01);
           this.Customer_DataView.ListChanged -= new ListChangedEventHandler(this.Customer_DataView_ListChangedForUD01);
           this.Customer_DataView = null;
           this.epiUltraGridC1.KeyDown -= new System.Windows.Forms.KeyEventHandler(this.epiUltraGridC1_KeyDown);
           this.epiUltraGridC1.BeforeRowsDeleted -= new Infragistics.Win.UltraWinGrid.BeforeRowsDeletedEventHandler(this.epiUltraGridC1_BeforeRowsDeleted);
           this.epiUltraGridC1.BeforeRowInsert -= new Infragistics.Win.UltraWinGrid.BeforeRowInsertEventHandler(this.epiUltraGridC1_BeforeRowInsert);
Â
           // Begin Custom Code Disposal
Â
           // End Custom Code Disposal
Â
     private void InitializeUD01Adapter()
           // Create an instance of the Adapter.
           this._ud01Adapter = new UD01Adapter(this.oTrans);
           this._ud01Adapter.BOConnect();
Â
           // Add Adapter Table to List of Views
           // This allows you to bind controls to the custom UD Table
           this._edvUD01 = new EpiDataView();
           this._edvUD01.dataView = new DataView(this._ud01Adapter.UD01Data.UD01);
           this._edvUD01.AddEnabled = true;
           this._edvUD01.AddText = "New Unit";
           if ((this.oTrans.EpiDataViews.ContainsKey("UD01View") == false))
                 this.oTrans.Add("UD01View", this._edvUD01);
Â
           // Initialize EpiDataView field.
           this._edvCustomer = ((EpiDataView)(this.oTrans.EpiDataViews["Customer"]));
Â
           // Set the parent view / keys for UD child view
           string[] parentKeyFields = new string[1];
           string[] childKeyFields = new string[1];
           parentKeyFields[0] = "CustNum";
           childKeyFields[0] = "Key1";
           this._edvUD01.SetParentView(this._edvCustomer, parentKeyFields, childKeyFields);
Â
           if ((this.oTrans.PrimaryAdapter != null))
                 // this.oTrans.PrimaryAdapter.GetCurrentDataSet(Epicor.Mfg.UI.Searches.DataSetMode.RowsDataSet).Tables.Add(this._edvUD01.dataView.Table.Clone())
Â
Â
     private void GetUD01Data(string key1, string key2, string key3, string key4, string key5)
           if ((this._Key1UD01 != key1) || (this._Key2UD01 != key2) || (this._Key3UD01 != key3) || (this._Key4UD01 != key4) || (this._Key5UD01 != key5))
                 // Build where clause for search.
                 string whereClause = "Key1 = \'" + key1 + "\' And Key2 = \'" + key2 + "\' And Key3 = \'" + key3 + "\' And Key4 = \'" + key4 + "\'";
                 System.Collections.Hashtable whereClauses = new System.Collections.Hashtable(1);
                 whereClauses.Add("Unit", whereClause);
Â
                 // Call the adapter search.
                 SearchOptions searchOptions = SearchOptions.CreateRuntimeSearch(whereClauses, DataSetMode.RowsDataSet);
                 this._ud01Adapter.InvokeSearch(searchOptions);
Â
                 if ((this._ud01Adapter.UD01Data.UD01.Rows.Count > 0))
                       this._edvUD01.Row = 0;
                 } else
                       this._edvUD01.Row = -1;
Â
                 // Notify that data was updated.
                 this._edvUD01.Notify(new EpiNotifyArgs(this.oTrans, this._edvUD01.Row, this._edvUD01.Column));
Â
                 // Set key fields to their new values.
                 this._Key1UD01 = key1;
                 this._Key2UD01 = key2;
                 this._Key3UD01 = key3;
                 this._Key4UD01 = key4;
                 this._Key5UD01 = key5;
Â
     private void GetNewUD01Record()
           DataRow parentViewRow = this._edvCustomer.CurrentDataRow;
           // Check for existence of Parent Row.
           if ((parentViewRow == null))
                 return;
           if (this._ud01Adapter.GetaNewUD01())
                 string custnum = parentViewRow["CustNum"].ToString();
Â
                 // Get unique row count id for Key5
                 int rowCount = this._ud01Adapter.UD01Data.UD01.Rows.Count;
                 int lineNum = rowCount;
                 bool goodIndex = false;
                 while ((goodIndex == false))
                       // Check to see if index exists
                       DataRow[] matchingRows = this._ud01Adapter.UD01Data.UD01.Select("Key5 = \'" + lineNum.ToString() + "\'");
                       if ((matchingRows.Length > 0))
                             lineNum = (lineNum + 1);
                       } else
                             goodIndex = true;
Â
                 // Set initial UD Key values
                 DataRow editRow = this._ud01Adapter.UD01Data.UD01.Rows[(rowCount - 1)];
                 editRow.BeginEdit();
                 editRow["Key1"] = custnum;
                 editRow["Key2"] = string.Empty;
                 editRow["Key3"] = string.Empty;
                 editRow["Key4"] = string.Empty;
                 editRow["Key5"] = lineNum.ToString();
                 editRow.EndEdit();
Â
                 this._edvUD01.Notify(new EpiNotifyArgs(this.oTrans, (rowCount - 1), this._edvUD01.Column));
Â
     private void SaveUD01Record()
           // Save adapter data
           this._ud01Adapter.Update();
Â
     private void DeleteUD01Record()
           // Check to see if deleted view is ancestor view
           bool isAncestorView = false;
           Epicor.Mfg.UI.FrameWork.EpiDataView parView = this._edvUD01.ParentView;
           while ((parView != null))
                 if ((this.oTrans.LastView == parView))
                       isAncestorView = true;
                       break;
                 } else
                       parView = parView.ParentView;
Â
           // If Ancestor View then delete all child rows
           if (isAncestorView)
                 DataRow[] drsDeleted = this._ud01Adapter.UD01Data.UD01.Select("Key1 = \'" + this._Key1UD01 + "\' AND Key2 = \'" + this._Key2UD01 + "\' AND Key3 = \'" + this._Key3UD01 + "\' AND Key4 = \'" + this._Key4UD01 + "\'");
                 for (int i = 0; (i < drsDeleted.Length); i = (i + 1))
                       this._ud01Adapter.Delete(drsDeleted[i]);
           } else
                 if ((this.oTrans.LastView == this._edvUD01))
                       if ((this._edvUD01.Row >= 0))
                             DataRow drDeleted = ((DataRow)(this._ud01Adapter.UD01Data.UD01.Rows[this._edvUD01.Row]));
                             if ((drDeleted != null))
                                   if (this._ud01Adapter.Delete(drDeleted))
                                         if ((_edvUD01.Row > 0))
                                               _edvUD01.Row = (_edvUD01.Row - 1);
Â
Â
     private void UndoUD01Changes()
           this._ud01Adapter.UD01Data.RejectChanges();
Â
Â
     private void ClearUD01Data()
Â
           this._ud01Adapter.UD01Data.Clear();
Â
Â
     private void baseToolbarsManager_ToolClickForUD01(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs args)
           // EpiMessageBox.Show(args.Tool.Key);
           switch (args.Tool.Key)
                 case "EpiAddNewNew Unit":
                       GetNewUD01Record();
                       break;
    Â
                 case "ClearTool":
                       ClearUD01Data();
                       break;
    Â
                 case "DeleteTool":
                       DeleteUD01Record();
                       break;
    Â
                 case "UndoTool":
                       UndoUD01Changes();
                       break;
Â
     private void CustomerEntryForm_BeforeToolClickForUD01(object sender, Epicor.Mfg.UI.FrameWork.BeforeToolClickEventArgs args)
                 case "SaveTool":
                       SaveUD01Record();
                       break;
Â
     private void Customer_AfterRowChangeForUD01(EpiRowChangedArgs args)
           // ** add AfterRowChange event handler
           string custnum = args.CurrentView.dataView[args.CurrentRow]["CustNum"].ToString();
           GetUD01Data(custnum, string.Empty, string.Empty, string.Empty, string.Empty);
Â
     private void Customer_DataView_ListChangedForUD01(object sender, ListChangedEventArgs args)
           // ** add ListChanged event handler
           string custnum = Customer_DataView[0]["CustNum"].ToString();
Â
     private void epiUltraGridC1_KeyDown(object sender, System.Windows.Forms.KeyEventArgs args)
           // Event handling code generated by wizard.
           if ((args.KeyCode == Keys.Escape))
                 try
                       UndoUD01Changes();
                 } catch (System.Exception )
Â
     private void epiUltraGridC1_BeforeRowsDeleted(object sender, Infragistics.Win.UltraWinGrid.BeforeRowsDeletedEventArgs args)
           args.Cancel = true;
           try
                 DeleteUD01Record();
Â
     private void epiUltraGridC1_BeforeRowInsert(object sender, Infragistics.Win.UltraWinGrid.BeforeRowInsertEventArgs args)
           args.Cancel = true;
           this.oTrans.SetCurrentEvent(TransactionEvent.AddNewOnNewFromGrid);
           try
                 SaveUD01Record();
                 GetNewUD01Record();
Â
     private void CustomerEntryForm_Load(object sender, EventArgs args)
           // Add Event Handler Code
     EpiUltraGrid myGrid = (EpiUltraGrid)csm.GetNativeControlReference("6eae7622-3412-4609-8f63-751abdca5f7a");
        myGrid.DisplayLayout.Bands[0].Columns["ShortChar07"].ValueList = epiComboC8;
Â
</div>
<div style="color:#fff;"></div>
</div>
</div>
</div>
</div>
<div style="color:#fff;min-height:0;"></div>
PROGRAM ID:  Customization
EXPECTED BEHAVIOR:  No error should be received.
***Note:  See attached customization example step 1:
Step 2:
Step 3:
_dtUD05.Clear();
_dtUD05 = null;
Step 4:
Step 5:
Step 6:
using System;
using System.Data;
using Epicor.Mfg.BO;
public class Script
                  } else
                  return;
                        } else
                              goodIndex = true;
                  editRow.EndEdit();
                        break;
                  } else
            if (isAncestorView)
            } else
                        GetNewUD01Record();
                        break;
                  case "ClearTool":
                        ClearUD01Data();
                        break;
                  case "DeleteTool":
                        DeleteUD01Record();
                        break;
                  case "UndoTool":
                        UndoUD01Changes();
                        break;
                  case "SaveTool":
                        SaveUD01Record();
                        break;
                  try
                        UndoUD01Changes();
            args.Cancel = true;
            try
                  DeleteUD01Record();
            args.Cancel = true;
            try
                  SaveUD01Record();
                  GetNewUD01Record();
This was Epicor's response when they could not get it to work either:
Step 2:
Step 3:
_dtUD05.Clear();
_dtUD05 = null;
Step 4:
Step 5:
Step 6:
using System;
using System.Data;
public class Script
                  } else
                  return;
                        } else
                              goodIndex = true;
                  editRow.EndEdit();
                        break;
                  } else
            if (isAncestorView)
            } else
                        GetNewUD01Record();
                        break;
                  case "ClearTool":
                        ClearUD01Data();
                        break;
                  case "DeleteTool":
                        DeleteUD01Record();
                        break;
                  case "UndoTool":
                        UndoUD01Changes();
                        break;
                  case "SaveTool":
                        SaveUD01Record();
                        break;
                  try
                        UndoUD01Changes();
            args.Cancel = true;
            try
                  DeleteUD01Record();
            args.Cancel = true;
            try
                  SaveUD01Record();
                  GetNewUD01Record();
Jose C Gomez
Software Engineer
E: jose@...
     Â
Â
<div>
  <p></p><p>This was Epicor&#39;s response when they could not get it to work either:</p><p></p><p>
Â
Â
Â
Â
Â
Â
Â
Â
Â
Step 2:
Â
Â
Step 3:
Â
_dtUD05.Clear();
_dtUD05 = null;
Â
Â
Step 4:
Â
Â
Â
Step 5:
Â
Â
Step 6:
Â
Â
using System;
using System.Data;
Â
public class Script
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
                 } else
Â
Â
Â
                 return;
Â
                       } else
                             goodIndex = true;
Â
                 editRow.EndEdit();
Â
Â
Â
                       break;
                 } else
Â
           if (isAncestorView)
           } else
Â
Â
Â
Â
Â
Â
Â
                       GetNewUD01Record();
                       break;
    Â
                 case "ClearTool":
                       ClearUD01Data();
                       break;
    Â
                 case "DeleteTool":
                       DeleteUD01Record();
                       break;
    Â
                 case "UndoTool":
                       UndoUD01Changes();
                       break;
Â
                 case "SaveTool":
                       SaveUD01Record();
                       break;
Â
Â
Â
                 try
                       UndoUD01Changes();
Â
           args.Cancel = true;
           try
                 DeleteUD01Record();
Â
           args.Cancel = true;
           try
                 SaveUD01Record();
                 GetNewUD01Record();
Â
Â
<p></p></div>
<div id="ygrps-yiv-1884614166yiv1280699781ygrp-text">
  <div dir="ltr"><div class="ygrps-yiv-1884614166yiv1280699781gmail_default" style="font-family:verdana, sans-serif;font-size:small;">Upload or put your original customization here and let me take a look at it (What version?)</div></div><div class="ygrps-yiv-1884614166yiv1280699781gmail_extra">
Jose C Gomez
Software Engineer
<div>
Step 2:
Step 3:
_dtUD05.Clear();
_dtUD05 = null;
Step 4:
Step 5:
Step 6:
using System;
using System.Data;
public class Script
                  } else
                  return;
                        } else
                              goodIndex = true;
                  editRow.EndEdit();
                        break;
                  } else
            if (isAncestorView)
            } else
                        GetNewUD01Record();
                        break;
                  case "ClearTool":
                        ClearUD01Data();
                        break;
                  case "DeleteTool":
                        DeleteUD01Record();
                        break;
                  case "UndoTool":
                        UndoUD01Changes();
                        break;
                  case "SaveTool":
                        SaveUD01Record();
                        break;
                  try
                        UndoUD01Changes();
            args.Cancel = true;
            try
                  DeleteUD01Record();
            args.Cancel = true;
            try
                  SaveUD01Record();
                  GetNewUD01Record();
</div>
</div>
Jose C Gomez
Software Engineer
E: jose@...
     Â
Â
<div>
  <p></p><div style="font-size:12pt;font-family:times new roman, new york, times, serif;">Alright I added it to the 9.0 files. We are on version 9.05.701. Error comes when selecting any record in the grid on the added sheet and trying to delete.<br>
Â
<div>
Jose C Gomez
Software Engineer
E: jose@...
     Â
Â
<div>
Â
Â
Â
Â
Â
Â
Â
Â
Â
Step 2:
Â
Â
Step 3:
Â
_dtUD05.Clear();
_dtUD05 = null;
Â
Â
Step 4:
Â
Â
Â
Step 5:
Â
Â
Step 6:
Â
Â
using System;
using System.Data;
Â
public class Script
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
Â
                 } else
Â
Â
Â
                 return;
Â
                       } else
                             goodIndex = true;
Â
                 editRow.EndEdit();
Â
Â
Â
                       break;
                 } else
Â
           if (isAncestorView)
           } else
Â
Â
Â
Â
Â
Â
Â
                       GetNewUD01Record();
                       break;
    Â
                 case "ClearTool":
                       ClearUD01Data();
                       break;
    Â
                 case "DeleteTool":
                       DeleteUD01Record();
                       break;
    Â
                 case "UndoTool":
                       UndoUD01Changes();
                       break;
Â
                 case "SaveTool":
                       SaveUD01Record();
                       break;
Â
Â
Â
                 try
                       UndoUD01Changes();
Â
           args.Cancel = true;
           try
                 DeleteUD01Record();
Â
           args.Cancel = true;
           try
                 SaveUD01Record();
                 GetNewUD01Record();
Â
Â
</div>
</div>
</div>
To get the error, navigate to the tab 'Unit Information' under the main customer tab. Add 2 new records and then try selecting one of the records in the grid and deleting it.
<div id="ygrps-yiv-1193765465yiv1640802465ygrp-text">
  <div dir="ltr"><div class="ygrps-yiv-1193765465yiv1640802465gmail_default" style="font-family:verdana, sans-serif;font-size:small;">I loaded your customization in my environment and had no problems. Do you have visual studio 2010? If so you can connect it to your customization and step through the code to identify the culplit line once we have that infromation we might be able to write something around it.</div>
Jose C Gomez
Software Engineer
<div>
<div>
Jose C Gomez
Software Engineer
<div>
Step 2:
Step 3:
_dtUD05.Clear();
_dtUD05 = null;
Step 4:
Step 5:
Step 6:
using System;
using System.Data;
public class Script
                  } else
                  return;
                        } else
                              goodIndex = true;
                  editRow.EndEdit();
                        break;
                  } else
            if (isAncestorView)
            } else
                        GetNewUD01Record();
                        break;
                  case "ClearTool":
                        ClearUD01Data();
                        break;
                  case "DeleteTool":
                        DeleteUD01Record();
                        break;
                  case "UndoTool":
                        UndoUD01Changes();
                        break;
                  case "SaveTool":
                        SaveUD01Record();
                        break;
                  try
                        UndoUD01Changes();
            args.Cancel = true;
            try
                  DeleteUD01Record();
            args.Cancel = true;
            try
                  SaveUD01Record();
                  GetNewUD01Record();
</div>
</div>
</div>
</div>
