I have an Case when statement that goes like this:
Case When OH > 0 then OH-Calculated_Sugg else ’ ’ end
This always errors out as an NVARCHAR to Decimal conversion failure. When I put a zero in, it works. How can I get it to be blank if its less than zero.
@Will79 If this calculated field returns a decimal data type, then feeding it an empty string will throw the error. Try NULL after the “else” in your code instead.
