Linda, et al,
 The reason I had attached partcost as a FKV was that the View available (cost)
had only the standard fields available (all of the avg cost, last cost and std
cost fields) , but not any optional or user-modifiable fields such as
number01-10, character and shortchar, etc. Is there any way to add any
combination of these fields to the standard view (cost) or is this an Epicor
locked-in-stone view? The alternative would be to bring in a BPM as Linda
suggests and push the values to a UD table.
 The reason I lean to putting the desired results into the partcost table is
that I have a costed Bill of Material report that I would prefer to not have
to link in yet another table.
-Karl
To: Karl Dash <dashkarl@...>
Sent: Wed, November 3, 2010 10:38:35 AM
Subject: RE: [Vantage] Numeric field not editable
Hi Karl,
Â
Maybe you could use a BPM to update the field. Â
Â
Add a field to the screen using a table that you can enter data into, then
create a BPM to update the PartCost.Number01 field when the value on the screen
changes.
Â
Regards,
Linda
Â
Sent: Wednesday, November 03, 2010 1:17 PM
To: Linda Lowney
Subject: Re: [Vantage] Numeric field not editable
Â
So, the answer is ... the field I was trying to put data into was the result of
a foreign key value and FKV fields are read only.
Â
Crud.
Â
FYI,
-Karl
Sent: Wed, November 3, 2010 7:09:35 AM
Â
Sorry Karl, I’m all out of ideas, lol.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karl
Dash
Sent: Wednesday, November 03, 2010 9:40 AM
Linda,
I turned the EpiKeyField to true but the custom field of mine is still grayed
out. the 'Data' portion of the properties is also grayed out and specifically
DataReadOnly is still true.
Appreciate the response. Any other thoughts?
-Karl
From: Linda Lowney <llowney@... <mailto:llowney%40pridesigns.com> >
Sent: Wed, November 3, 2010 5:09:49 AM
Try turning on the Key Field property.
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of Karl
Dash
Sent: Tuesday, November 02, 2010 5:26 PM
To: Vantage Group
Subject: [Vantage] Numeric field not editable
I have added a custom field (partcost.Number01) to a screen to capture various
miscellaneous costs. The field shows up in the 'Data' portion of the properties
as DataReadOnly with a value of true. The property field is grayed out and can't
be changed. As a result I can't enter any values into this field. Is this a case
where VB code needs to change the property to 'true'?
I am on 803.408.
-Karl
-Karl
Hi Karl,
Â
Â
changes.
Â
Regards,
Linda
Â
To: Linda Lowney
Â
Â
Crud.
Â
FYI,
-Karl
Â
Dash
Linda,
-Karl
Of Karl
Dash
To: Vantage Group
I am on 803.408.
-Karl
