In the last two weeks my scheduling has went from working mediocrely to not working at all. I cannot find the error after searching through both settings and multiple jobs and reading through the error message is not enlightening me as to where I need to look. If anyone else can make sense of this and point me in the correct direction, it would be greatly appreciated.
07:52:53 MRP finite scheduling process begin.
07:52:53 ------------------------------------------------------------
07:52:53 Cut Off Date ->
07:52:53 Schedule Start Date -> 1/19/2022 12:00:00 AM
07:52:53 Run Finite Scheduling -> True
07:52:53 Ignore Constrained Materials -> False
07:52:53 Allow Historical Dates -> False
07:52:53 Use Production Preparation Buffer -> True
07:52:53 Process Control Queue
07:52:53 Group -> Job; Queue -> SchedJobF; Type -> Job; Finite -> True
07:52:53 Group -> Job; Queue -> SchedJobI; Type -> Job; Finite -> False
07:52:53 Check List -> SchedJobF~SchedJobI; Last Group -> False
07:52:53 Group -> Load; Queue -> SaveLoad; Type -> Job; Finite -> False
07:52:53 Check List -> SaveLoad; Last Group -> True
07:53:01 Starting Part Level: 0-0. Wait Time: 00h:00m:00s:000ms, Jobs: 0
07:53:01 Scheduling new unfirm job:054022
07:53:06 The job is currently scheduled to finish 6/12/2024. It will not meet its required date of 12/31/2021 as the Company doesn’t allow scheduling in the past.
07:53:06 Done Scheduling job:054022 sending job to queue SaveLoad
07:53:06 Scheduling new unfirm job:003717-1-1
07:53:21 System.NullReferenceException: Object reference not set to an instance of an object.
at Erp.Internal.ES.SchedEngine.MoveJobItem(String ttScheduleEngineCompany, String ttScheduleEngineJobNum, Int32 ttScheduleEngineAssemblySeq, Int32 ttScheduleEngineOprSeq, Int32 ttScheduleEngineOpDtlSeq, Nullable`1 ttScheduleEngineStartDate, Int32 ttScheduleEngineStartTime, Nullable`1 ttScheduleEngineEndDate, Int32 ttScheduleEngineEndTime, Boolean ttScheduleEngineWhatIf, Boolean ttScheduleEngineFinite, String ttScheduleEngineSchedTypeCode, Boolean ttScheduleEngineOverrideMtlCon, Int32 OverRideHistDateSetting, Boolean ttScheduleEngineScheduleDir, Boolean il_surpressexceptions, Int32 ttScheduleEngineAllocNum, String& WarnLogTxt, Boolean ttScheduleEngineMinimizeWIP, Nullable`1 ipOverrideBounceDate) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\ES\SchedEngine\SchedEngine.cs:line 15565
at Erp.Internal.ES.SchedEngine.doMultiSchedule(ScheduleEngineRow ScheduleEngine, Boolean scheduleDirection, Nullable`1 ipDate, Int32 ipTime, List`1 ipSchedItemRows, Boolean ipDoingPartial) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\ES\SchedEngine\SchedEngine.cs:line 14860
at Erp.Internal.ES.SchedEngine.moveMultiJobItem(ScheduleEngineRow ttScheduleEngine, List`1 ipSchedItemRows, List`1 ipSchedRelItemRows) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\ES\SchedEngine\SchedEngine.cs:line 15330
at Erp.Internal.ES.SchedEngine.MoveItem(ScheduleEngineRow ttScheduleEngine, String& opWarnLogTxt) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\ES\SchedEngine\SchedEngine.cs:line 14541
at Erp.Internal.ES.SchedEngine.MoveGlobalJob(String ttScheduleEngineCompany, String ttScheduleEngineJobNum, Int32 ttScheduleEngineAssemblySeq, Int32 ttScheduleEngineOprSeq, Int32 ttScheduleEngineOpDtlSeq, Nullable`1 ttScheduleEngineStartDate, Int32 ttScheduleEngineStartTime, Nullable`1 ttScheduleEngineEndDate, Int32 ttScheduleEngineEndTime, Boolean ttScheduleEngineWhatIf, Boolean ttScheduleEngineFinite, String ttScheduleEngineSchedTypeCode, Boolean ttScheduleEngineOverrideMtlCon, Int32 OverRideHistDateSetting, Boolean ttScheduleEngineScheduleDir, Boolean il_surpressexceptions, Int64 instancetasknum, Int32 ttScheduleEngineAllocNum, Nullable`1 GlobalBounceDate, Decimal GlobalBounceTimeParam, Boolean ttLogfile, Boolean multiJob, String& WarnLogTxt, Boolean ignoreLocks, Boolean ipMinimizeWIP) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\ES\SchedEngine\SchedEngine.cs:line 14122
at Erp.Internal.MR.MrpExpSched.schedUnfirmJob(Int64 instance_TaskNum, Boolean finiteLoad, Boolean whatif, String new_job_num, String jobFlag, Boolean firmFlag, Nullable`1 jobStartDate, Int32 jobStartTime, Boolean jobForward, Int32 pLevel, Boolean pMethod, Int32 jobPri, String pOutQueue, String qText, String pInQueue, String pOutQueue1, String pOutType, String pOutType1, Int32 pSubLLC, String procSource, Int32 processNum, Nullable`1 Sched_startDate, String logfile, Int32 loglevel, Boolean ignoreConst, Boolean allowHistDate, Decimal GSStartTime, Boolean multiJob, Boolean multiJobIgnoreLocks, Boolean multiJobMinimizeWIP, Boolean& errFlag) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\MR\MrpExpSched\MrpExpSched.cs:line 0
at Erp.Internal.MR.MrpExpSched.main_block(Int64 instance_TaskNum, Boolean netchg, String IP_plantList, Nullable`1 cutoff_date, Boolean from_autopur, String logfile, Int32 loglevel, Boolean finiteLoad, Boolean ignoreConst, Boolean allowHistDate, Boolean usePrepTime, Boolean useKitTime, Boolean runPegging, Boolean runConPur, Nullable`1 Sched_startDate, String ShipViaDefault, String compBuyerID, Int32 ForeDaysB, Int32 ForeDaysA, String v_defaultSchedCode, String extComp, String PlantSelected, String plantprefixlist, String pReqType, Int32 processNum, String purDir, Boolean whatif, String procSource, Decimal GSStartTime, Boolean delaySched, Boolean recyclejobs, Boolean rcSchedGetDetails, Boolean includePCParts, Boolean useQuoteBOM, Boolean multiJob, Boolean multiJobIgnoreLocks, Boolean multiJobMinimizeWIP) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\MR\MrpExpSched\MrpExpSched.cs:line 3613
at Erp.Internal.MR.MrpExpSched.RunMrpExpSched(Int64 instance_TaskNum, Boolean netchg, String IP_plantList, Nullable`1 cutoff_date, Boolean from_autopur, String logfile, Int32 loglevel, Boolean finiteLoad, Boolean ignoreConst, Boolean allowHistDate, Boolean usePrepTime, Boolean useKitTime, Boolean runPegging, Boolean runConPur, Nullable`1 Sched_startDate, String ShipViaDefault, String compBuyerID, Int32 ForeDaysB, Int32 ForeDaysA, String v_defaultSchedCode, String extComp, String PlantSelected, String plantprefixlist, String pReqType, Int32 processNum, String purDir, Boolean whatif, String procSource, Decimal GSStartTime, Boolean delaySched, Boolean recyclejobs, Boolean rcSchedGetDetails, Boolean includePCParts, Boolean useQuoteBOM, Boolean multiJob, Boolean multiJobIgnoreLocks, Boolean multiJobMinimizeWIP) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\MR\MrpExpSched\MrpExpSched.cs:line 1034
at Erp.Internal.MR.MrpExpSched.RunSubProcess(List`1 Parameters) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\MR\MrpExpSched\MrpExpSched.cs:line 739
07:53:21 at Erp.Internal.ES.SchedEngine.MoveJobItem(String ttScheduleEngineCompany, String ttScheduleEngineJobNum, Int32 ttScheduleEngineAssemblySeq, Int32 ttScheduleEngineOprSeq, Int32 ttScheduleEngineOpDtlSeq, Nullable`1 ttScheduleEngineStartDate, Int32 ttScheduleEngineStartTime, Nullable`1 ttScheduleEngineEndDate, Int32 ttScheduleEngineEndTime, Boolean ttScheduleEngineWhatIf, Boolean ttScheduleEngineFinite, String ttScheduleEngineSchedTypeCode, Boolean ttScheduleEngineOverrideMtlCon, Int32 OverRideHistDateSetting, Boolean ttScheduleEngineScheduleDir, Boolean il_surpressexceptions, Int32 ttScheduleEngineAllocNum, String& WarnLogTxt, Boolean ttScheduleEngineMinimizeWIP, Nullable`1 ipOverrideBounceDate) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Internal\ES\SchedEngine\SchedEngine.cs:line 15565
