I am adding some buttons to our MES menu and have been able to successfully add some dashboards. I have several DynamicCriteriaReports that I have been unable to launch from MES.
I get the error that the menu ID is not valid from the MES Menu. Is it because these types of reports cannot be added to the MES Screen? I tried adding the report to the Processes menu, which was suggested to me but that doesn’t seem to change anything.
@vfeldt Did you ever get a answer to this? I am trying to run certain things from MES and getting the same issue, not sure if Epicor has put limits on what can be run from MES.
I had to go back and re-create the reports using BAQ Report Designer instead of creating the RDD that used a BAQ with parameters and ReportStyle maintenance
With the BAQ Report Designer I left the BAQ without parameters and added an option and filter to the BAQ Report.
