<div id="ygrps-yiv-1726979935yiv7555298023ygrp-text">
<div>Another way to look at the process Epicor has set up there with design intent is a three step/phase approach; Non-Conformance (phase I) is raising your hand ‘I think I have a problem here’, Phase II Inspection Processing is where we confirm or deny that we do in fact have a problem (i.e. parts out of spec – forward to phase III or there is no problem, kick them back into play), and finally Phase III DMR processing is where we decide how we will disposition the bad parts (scrap, rework, return to vendor etc..).
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Wednesday, May 27, 2015 12:08 PM
Subject: Re: [Vantage] Re: Non-Conformance and DMR process question
When you do the inspection processing you are working the non-conformance. The non-conformance id is available at that time.
Sent from my Verizon 4G LTE Smartphone
----- Reply message -----
From: "Kimberley White faepigrl@... [vantage]" <vantage@yahoogroups.com>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Subject: [Vantage] Re: Non-Conformance and DMR process question
Date: Wed, May 27, 2015 11:23 AM
When we fail a part from PO Receipts in Inspection Processing it creates a DMR# but not a Non-Conformance.
We are trying to help Quality get using what we have and their processes seem skewed. So I am learning too.
On Wednesday, May 27, 2015 11:15 AM, "'Bethany Rye' brye@... [vantage]" <vantage@yahoogroups.com> wrote:
Your PO Receipts go to Inspection Processing on the PO Receipts tab which is done within the same window (Production Management > Quality Assurance > General Operations > Inspection Processing) as Non-conformance Operations only those are done on the Operations tab (this is for manufactured parts needing inspection due to an operation). So in essence, the PO Receipt is treated like a non-conformance and I believe it is assigned a Non-conformance number.
From there, if the quantity is “passedâ€, it goes to stock, a job, or a subcontract job. The “failed†quantity goes to a DMR for processing.
Bethany Rye
Epicor Business Analyst
PTI Engineered Plastics
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023 --
#ygrps-yiv-1726979935yiv7555298023ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mkp #ygrps-yiv-1726979935yiv7555298023hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mkp #ygrps-yiv-1726979935yiv7555298023ads {
margin-bottom:10px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mkp .ygrps-yiv-1726979935yiv7555298023ad {
padding:0 0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mkp .ygrps-yiv-1726979935yiv7555298023ad p {
margin:0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mkp .ygrps-yiv-1726979935yiv7555298023ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-sponsor #ygrps-yiv-1726979935yiv7555298023ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-sponsor #ygrps-yiv-1726979935yiv7555298023ygrp-lc #ygrps-yiv-1726979935yiv7555298023hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-sponsor #ygrps-yiv-1726979935yiv7555298023ygrp-lc .ygrps-yiv-1726979935yiv7555298023ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023activity span {
font-weight:700;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023activity span span {
color:#ff7900;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023activity span .ygrps-yiv-1726979935yiv7555298023underline {
text-decoration:underline;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023attach div a {
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023attach label a {
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023bold a {
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 dd.ygrps-yiv-1726979935yiv7555298023last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 dd.ygrps-yiv-1726979935yiv7555298023last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 dd.ygrps-yiv-1726979935yiv7555298023last p span.ygrps-yiv-1726979935yiv7555298023yshortcuts {
margin-right:0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023attach-table div div a {
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023attach-table {
width:400px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023file-title a, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023file-title a:active, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023file-title a:hover, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023file-title a:visited {
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023photo-title a, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023photo-title a:active, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023photo-title a:hover, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div.ygrps-yiv-1726979935yiv7555298023photo-title a:visited {
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 div#ygrps-yiv-1726979935yiv7555298023ygrp-mlmsg #ygrps-yiv-1726979935yiv7555298023ygrp-msg p a span.ygrps-yiv-1726979935yiv7555298023yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023green {
color:#628c2a;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 o {
font-size:0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023photos div {
float:left;width:72px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023reco-category {
font-size:77%;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023reco-desc {
font-size:77%;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 .ygrps-yiv-1726979935yiv7555298023replbq {
margin:4px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mlmsg select, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 input, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mlmsg pre, #ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 code {
font:115% monospace;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-mlmsg #ygrps-yiv-1726979935yiv7555298023logo {
padding-bottom:10px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-msg p#ygrps-yiv-1726979935yiv7555298023attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-reco #ygrps-yiv-1726979935yiv7555298023reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-sponsor #ygrps-yiv-1726979935yiv7555298023ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-sponsor #ygrps-yiv-1726979935yiv7555298023ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-sponsor #ygrps-yiv-1726979935yiv7555298023ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1726979935 #ygrps-yiv-1726979935yiv7555298023 #ygrps-yiv-1726979935yiv7555298023ygrp-vital ul li:last-child {
border-right:none !important;}
