<div id="ygrps-yiv-1769995558yiv0608238456ygrp-text">
<div></div><div class="ygrps-yiv-1769995558yiv0608238456WordSection1"><div class="ygrps-yiv-1769995558yiv0608238456MsoNormal">Your PO Receipts go to Inspection Processing on the PO Receipts tab which is done within the same window (Production Management > Quality Assurance > General Operations > Inspection Processing) as Non-conformance Operations only those are done on the Operations tab (this is for manufactured parts needing inspection due to an operation). So in essence, the PO Receipt is treated like a non-conformance and I believe it is assigned a Non-conformance number. </div><div class="ygrps-yiv-1769995558yiv0608238456MsoNormal"> </div><div class="ygrps-yiv-1769995558yiv0608238456MsoNormal">From there, if the quantity is “passedâ€, it goes to stock, a job, or a subcontract job. The “failed†quantity goes to a DMR for processing.</div><div class="ygrps-yiv-1769995558yiv0608238456MsoNormal"> </div><div class="ygrps-yiv-1769995558yiv0608238456MsoNormal" style="margin-bottom:12pt;"><b><span style="color:rgb(64, 64, 64);font-size:10pt;">Bethany Rye</span></b><span style="font-size:12pt;"><br clear="none"></span><span style="color:rgb(64, 64, 64);font-size:10pt;">Epicor Business Analyst</span><span style="font-size:12pt;"> <br clear="none"></span>PTI Engineered Plastics</div></div>
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456 --
#ygrps-yiv-1769995558yiv0608238456ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mkp #ygrps-yiv-1769995558yiv0608238456hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mkp #ygrps-yiv-1769995558yiv0608238456ads {
margin-bottom:10px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mkp .ygrps-yiv-1769995558yiv0608238456ad {
padding:0 0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mkp .ygrps-yiv-1769995558yiv0608238456ad p {
margin:0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mkp .ygrps-yiv-1769995558yiv0608238456ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-sponsor #ygrps-yiv-1769995558yiv0608238456ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-sponsor #ygrps-yiv-1769995558yiv0608238456ygrp-lc #ygrps-yiv-1769995558yiv0608238456hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-sponsor #ygrps-yiv-1769995558yiv0608238456ygrp-lc .ygrps-yiv-1769995558yiv0608238456ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456activity span {
font-weight:700;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456activity span span {
color:#ff7900;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456activity span .ygrps-yiv-1769995558yiv0608238456underline {
text-decoration:underline;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456attach div a {
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456attach label a {
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456bold a {
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 dd.ygrps-yiv-1769995558yiv0608238456last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 dd.ygrps-yiv-1769995558yiv0608238456last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 dd.ygrps-yiv-1769995558yiv0608238456last p span.ygrps-yiv-1769995558yiv0608238456yshortcuts {
margin-right:0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456attach-table div div a {
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456attach-table {
width:400px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456file-title a, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456file-title a:active, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456file-title a:hover, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456file-title a:visited {
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456photo-title a, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456photo-title a:active, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456photo-title a:hover, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div.ygrps-yiv-1769995558yiv0608238456photo-title a:visited {
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 div#ygrps-yiv-1769995558yiv0608238456ygrp-mlmsg #ygrps-yiv-1769995558yiv0608238456ygrp-msg p a span.ygrps-yiv-1769995558yiv0608238456yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456green {
color:#628c2a;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 o {
font-size:0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456photos div {
float:left;width:72px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456reco-category {
font-size:77%;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456reco-desc {
font-size:77%;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 .ygrps-yiv-1769995558yiv0608238456replbq {
margin:4px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mlmsg select, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 input, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mlmsg pre, #ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 code {
font:115% monospace;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-mlmsg #ygrps-yiv-1769995558yiv0608238456logo {
padding-bottom:10px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-msg p#ygrps-yiv-1769995558yiv0608238456attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-reco #ygrps-yiv-1769995558yiv0608238456reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-sponsor #ygrps-yiv-1769995558yiv0608238456ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-sponsor #ygrps-yiv-1769995558yiv0608238456ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-sponsor #ygrps-yiv-1769995558yiv0608238456ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1769995558 #ygrps-yiv-1769995558yiv0608238456 #ygrps-yiv-1769995558yiv0608238456ygrp-vital ul li:last-child {
border-right:none !important;}
