Reported problems from our buyer below… Any pointers would be greatly appreciated.
Please explain why No PO Suggestion appears.
On 2/17/2021 I had ordered SD-8GB-BLANK for SO123502 on PO26695. The sales order is for quantity 500. The SD-8GB-BLANK are 96 min/mult. So the PO is for 576. Up until today we did not have a confirmed ship date on the PO26695. Constant expedites for over 1-1/2 years. Today I get shipping notification PO26695.
I want to let everyone know we can finally ship this Sales Order. I went into time phase to get the sales order. That is when I see we have another SO124070 needing 560 of this same part SD-8GB-BLANK. There is no PO suggestion showing in time phase. I have not purchased these. SO124070 was entered on 06/16/2021.
Did I see PO Suggestion for SO123502? I do not remember. I could have heard we got the order and sent the PO to the supplier or maybe I did get the suggestion in February.
Here is what Time Phase looks like right now. I have to get these on order so it will not look like this in a few minutes
Also the part seems have all the correct boxes checked that would make t Generate PO Suggestions (screenshots below.
Ah yes, i forgot about cutoff date… Can you remind me which date it looks at to know if it should plan?
Below is a screenshot of process MRP. Our cutoff date is blank, after reviewing past support cases I see Epicor support indicated a blank date indicates it should plan for everything, but in practice we were seeing it plan 6 weeks out…
Sorry I may be adding confusion. If helpful I rarely work in this area so my knowledge is not very good… I just looked at production planner and I see jobs through Dec 2023 listed, see screenshot below.
Any pointers where to go from here would be much appreciated!
Looking at the Time Phase window, it shows SO 124070/1/1, which takes the balance below zero, is due 6/6/2023 and a lead time of 182. So, a PO suggestion is not needed until 12/6/2022.
Correct an unfirmed sales order release will show up in time phase. Kudos to @LarsonSolutions for figuring this out in like 10 minutes
There is one pending question, I’ll start a new thread, as the suggestion from @jgreenaway has worried our buyer we won’t get PO suggestions until it’s time to buy, but the problem is with today’s supply chain issues lead times are a big unknown…
Hi Eddie, please let your buyer know my answer was incorrect. If MRP (or Generate Suggestions) is run with no cut-off date or at least past the date of need, they WILL get PO suggestions. I was wrong and should have edited my post.
