Isn’t PartLot a table already included in the original ARForm report Data Definition?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of SimsTrak Consulting
Sent: Monday, November 04, 2013 2:36 PM
Subject: RE: [Vantage] No Data appearing in added Table
First question, why are you creating a relationship between OrderHed and PartLot? It would seem to be OrderHed to InvcDtl.
Second, you probably don’t need to create a new relationship. On the InvcDtl table, there are Linked Tables, one of these is called “OrderNum†(why they don’t use the table name for the linked table – you got me). Make sure that table is picked, then go to the Report Table -> Linked Tables -> Description Fields and pick the fields you want. In your XML, these OrderHed fields don’t show up under a separate OrderHed table, instead they are shown as fields within the InvcDtl table. For example, the PONum field from OrderHed would be the “OrderHed_PONum†field on the InvcDtl table. Confused yet?
Kevin Simon
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of ingelstan@...
Sent: Monday, November 04, 2013 2:17 PM
Subject: [Vantage] No Data appearing in added Table
In Report Data Definition, i added OrderHed table to ARForm, first creating a duplicate report. I created a relationship from OrderHed to PartLot. When I bring in the table to the crystal report for there is no data appearing for any of the included fields.
Does this mean i need to create another relationship?? Anybody else run across this before?
Stan
