Just want to see what people are using for this when it comes to nightly report.
We have heard SSRS Breaking and Routing rules will do the job. We just want to reach out see if there is available module that Epicor already have before we planning to purchase the module.
You don’t even need Break/Routing (although it makes it easier).
Just run the report like you were going to print it or preview it. But set a schedule and make it recurring. And instead of clicking the Print or Preview Icon, click the email one. Then fill in the info in the email setup. NOTE! - hitting the enter key while typing in the Email Body field is the same as clicking the OK button.
When you do click the OK button the task goes to the scheduler and will run at the prescribed time.
You would need Break/Routing if you wanted fileds like the To: or Body: to be dependent on the content of the data (like only sending copies of orders to salesmen specified on the order).
And in case you wonder why there are scheduled reports for the Stock Status, it is because we have 4 sites, and send two versions (one in PDF and one in Excel) for each site.
Just my 2c here, don’t forget you can just create your own report with SSDT, or Report Builder and then create a subscription in SSRS report manager. Rather handy if you have data other than Epicor data you want to report on.
I learned this from a customer: APM can route reports via email by scheduling the report to run in Epicor and print to ERM, and if you want a distribution list, embed those email addresses in the header or footer of the report, change the font to white so it’s invisible, and specific sections of the report can be distributed separately, i.e., Priority Dispatch can be sent to each department supervisor but only their individual section of the report.
Another option is to create a Job in SSMS and schedule that to run as requested, i.e., an email to each supplier with their list of open purchase orders.
