I agree with Joe - you always need to have visibility of jobs requests.
Maybe the fix could be along the lines of when you go to make the job "firm"
a flag will be generated to warn you that an unapproved revision is used in
the BOM, do you want to use it?
Sent: Thursday, August 24, 2000 6:41 AM
To: vantage@egroups.com
Subject: Re: [Vantage] new MRP bug
You may not want to build it right now. But as it stands if sales
puts in an order you'll never know you're missing it until the
customer calls wanting their order. The system should give you
a suggestion then you can deal with it as you see fit.
Eric Tolliver wrote:
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
> Joe,
> Is that really considered a bug? I don't see where you would want to build
> something with no approved revision.
> Continental Industries Inc. Maker of Solid State Relays.
> 5456 E. McDowell Rd.
> Mesa, Az. 85215
> (480)985-7800 Ext. 217
> From: Joe Konecny [mailto:jkonecn@...]
> Those of you running MRP may want to take note of this...
> Subject:
> Call Number 593513MPS Technical Support Reply: MRP Mfg
> suggestion s not created for stock part when on hand is below zero...
> Date:
> Please reference call # 593513MPS if you have any additional questions
> on
> this issue.
> Joe,
> This issue has been written up with an SCR (software change request)
> which
> will require a schema change. See explanation below:
> PROBLEM:
> A sales order is created for a part that has a BOM, min and max
> quantities,
> but is a stock part with zero on hand and an unapproved revision. MRP
> does
> not create a job because the revision is unapproved. Mfg Suggestion is
> not
> created because it is a stock part, so how can Production be flagged
> that a
> job is needed? The system doesn't flag you in any way if a job cannot
> be
> set up through MRP.
> STEPS TO DUPLICATE:
> 1. Create a manufactured, stock part in the part master with a minimum
> on
> hand quantity and a minumum lot size. Add a BOM, but leave the revision
> unapproved.
> 2. Create a sales order for this part. As designed, the Make flag is
> set to
> No.
> 3. Run MRP. No job is created (because the rev is unapproved).
> 4. Look at Mfg Suggestion. No job is suggested.
> 5. Change the Sales Order to Make. A manufacturing suggestion now
> appears.
> 6. Approve the Rev, change the due date on the sales order, and run MRP
> Net
> Change.
> 7. MRP will now create a job.
> The point is, until you do steps 5 and/or 6, there is no visibility that
> a
> job should be created, other than looking at Time Phase.
> (Note: If this link does not work for you the first time you try it, goto www.egroups.com, login and be sure to save your password, choose My
