You do get a flag (a suggestion) if the job to be created is
make to order. If the job would be make to stock the
suggestion doesn't appear. That's the bug.
> We don't use MRP, but we like the idea of the flag that warns of an
> unapproved revision-or any kind of revision discrepancy!
> Lydia
> Canyon Engineering Products, Inc.
> -----Original Message-----
> From: Steve Lewis [mailto:slewis@...]
> Sent: Thursday, August 24, 2000 9:17 AM
> To: vantage@egroups.com
> Subject: RE: [Vantage] new MRP bug
> along the lines of when you go to make the job "firm" a flag will be
> generated to warn you that an unapproved revision is used in the BOM, do you
> want to use it?
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
