Have any of you been able to setup a network printer where all the server printer preferences can be called? We print a lot of Job Travellers which print in A3 and have a staple applied in the top left hand corner. On our old version of Epicor we would use client printing which would pick up the printer preferences from the print server and apply the stapling etc without any issues.
We are now moving to Network Printing and we are unable to get the stapling to apply. I was wondering if anyone has been able to achieve this or something similar in regards to pulling printer preferences that are not in Epicor Printer Maintenance.
The defaults on the printer are set to collate and staple but Epicor seems to ignore it when sending the job traveller through. My thoughts are that Epicor handles the limited settings it has for the Network Printer and just sends it using the shared printer without taking on any preferences local to the server/pc printer.
Thanks for that. For some reason on 10.1 it knew to collate with a staple without the setting on the default. I had a look and another printer share was setup from the same printer. Adjusted the Defaults and I now have printing and stapling from Epicor.
