Network Monitor
It would really depend on the types of errors you're seeing, but here is
an initial thought:
Does the server have any problems sending NON-Vantage data out? You can
try using "ping -t -l <size> <workstation-IP>" to send a large-packet
ping request from the server. Do this simultaneously targeting a few
different workstations and use a fairly big value for <size> (like 2048)
and see if you generate similar errors. This is a very quick and very
inaccurate test, but if you get similar errors, it might help diagnose
the issue.
--Ari
Of Blake Clemens
Sent: Friday, October 09, 2009 10:10 AM
Subject: [Vantage] Network Monitor
I have installed and have been running WireShark on our Vantage Server.
After viewing a few monitor reports I've found that when transmitting
information to the Vantage server its error-less. But when the server
transmits information back to the client PC it has errors. Does anyone
have any thoughts on what this could mean?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
