We will make sure it is in the ticket. This is it:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: The underlying provider failed on EnlistTransaction.
Stack Trace:
at System.Data.EntityClient.EntityConnection.EnlistTransaction(Transaction transaction)
at System.Data.Objects.ObjectContext.EnsureConnection()
at System.Data.Objects.ObjectQuery`1.GetResults(Nullable`1 forMergeOption)
at System.Data.Objects.ObjectQuery`1.System.Collections.Generic.IEnumerable<T>.GetEnumerator()
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable`1 source)
at System.Data.Objects.CompiledQuery.ExecuteQuery[TResult](ObjectContext context, Object[] parameterValues)
at Epicor.Data.DBExpressionCompiler.GetResult[TContext,TQuery,TResult](Func`3 executeQuery, Cache cacheSetting, TContext dataContext, TQuery query) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 441
at Epicor.Data.DBExpressionCompiler.InvokeSingle[TContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext dataContext, Func`2 getDataCacheKey, Func`2 compileQuery, Func`3 executeQuery) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 302
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass34_0`4.<Compile>b__0(TContext context, TArg1 arg1, TArg2 arg2) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 1110
at Erp.Internal.Lib.JobRcpnt.DoPerson(String In_PersonId, Int32 In_AlertNum) in c:\_Releases\ERP\RL10.1.500\Source\Server\Internal\Lib\JobRcpnt\JobRcpnt.cs:line 225
at Erp.Internal.Lib.JobRcpnt._JobRcpnt(String In_JobNum, Int32 In_AlertNum, String In_EmailList, String& RcpntList) in c:\_Releases\ERP\RL10.1.500\Source\Server\Internal\Lib\JobRcpnt\JobRcpnt.cs:line 118
at Erp.Internal.Lib.XAP05.Do_1150(String In_ParmList, Int32 In_AlertNum) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\Lib\Shared\XAP05\XAP05.cs:line 1794
at Erp.Internal.Lib.XAP05._XAP05(Int32 In_AlertNum, String In_ParmList, String& VContinue) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\Lib\Shared\XAP05\XAP05.cs:line 420
at Erp.Internal.Lib.JobOperWrite._JobOperWrite(JobOper JobOper, JobOper OldJobOper, Boolean RollUp) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\Lib\JobOperShared\JobOperWrite\JobOperWrite.i.cs:line 1013
at Erp.Internal.Lib.JobOperShWrite.DoJobOper(JobOper JobOper, JobOper OLDJobOper) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\Lib\JobOperShared\JobOperShWrite\JobOperShWrite.cs:line 1298
at Erp.Triggers.JobOper.WriteTrigger.write(JobOper JobOper, JobOper OldJobOper) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Db\Triggers\JobOper\write.cs:line 221
at Ice.Triggers.TriggerQueue.ExecuteWriteTrigger(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 296
at Ice.Triggers.TriggerQueue.RunWriteTriggerInNewLevel(IceDataContext context, LinqRow modifiedRecord, LinqRow originalRecord, Boolean forAddedRow) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 157
at Ice.Triggers.TriggerQueue.<>c__DisplayClass11_0.<RunWriteTrigger>b__1() in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 148
at Ice.Triggers.TriggerQueue.RunAtNewLevel(Func`1 buildTriggerRunState, Action action) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 501
at Ice.Triggers.TriggerQueue.RunTriggers(IceDataContext context) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 83
at Ice.IceDataContext.RunUntilAllTriggersHaveExecuted() in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 542
at Ice.IceDataContext.Validate[TLinqRow](TLinqRow row) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 299
at Erp.Triggers.LaborDtl.WriteTrigger.Write(LaborDtl LaborDtl, LaborDtl OLaborDtl) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Db\Triggers\LaborDtl\Write.cs:line 1525
at Erp.Internal.Lib.BFLaborD.CreateProduction() in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\Lib\BFLaborD\BFLaborD.cs:line 380
at Erp.Internal.Lib.BFLaborD.processLaborDtl(Guid LaborDtlRowid, String& oMessage) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\Lib\BFLaborD\BFLaborD.cs:line 220
at Erp.Internal.Lib.BFLaborD._BFLaborD(Guid LaborDtlRowid, String& oMessage) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\Lib\BFLaborD\BFLaborD.cs:line 139
at Erp.Internal.JC.BackflushLaborProcess.RunProcess(Int64 InstanceTaskNum, String OutputFileName) in D:\_Releases\ERP\UD10.1.500.31\Source\Server\Internal\JC\BackflushLaborProcess\BackflushLaborProcess.cs:line 174
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 93
at Ice.Hosting.TaskCaller.ExecuteTask() in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 54
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in D:\_Releases\ICE\3.1.500.31\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in D:\_Releases\ICE\3.1.500.31\Source\Server\Services\Lib\RunTask\RunTask.cs:line 526
Inner Exception:
The partner transaction manager has disabled its support for remote/network transactions. (Exception from HRESULT: 0x8004D025)
Stack Trace:
at System.Transactions.Oletx.OletxTransactionManager.ProxyException(COMException comException)
at System.Transactions.TransactionInterop.GetOletxTransactionFromTransmitterPropigationToken(Byte[] propagationToken)
at System.Transactions.TransactionStatePSPEOperation.PSPEPromote(InternalTransaction tx)
at System.Transactions.TransactionStateDelegatedBase.EnterState(InternalTransaction tx)
at System.Transactions.EnlistableStates.Promote(InternalTransaction tx)
at System.Transactions.Transaction.Promote()
at System.Transactions.TransactionInterop.ConvertToOletxTransaction(Transaction transaction)
at System.Transactions.TransactionInterop.GetExportCookie(Transaction transaction, Byte[] whereabouts)
at System.Data.SqlClient.SqlInternalConnection.GetTransactionCookie(Transaction transaction, Byte[] whereAbouts)
at System.Data.SqlClient.SqlInternalConnection.EnlistNonNull(Transaction tx)
at System.Data.SqlClient.SqlInternalConnection.Enlist(Transaction tx)
at System.Data.SqlClient.SqlInternalConnection.EnlistTransaction(Transaction transaction)
at System.Data.SqlClient.SqlConnection.EnlistTransaction(Transaction transaction)
at Epicor.Data.Provider.EpiConnection.EnlistTransaction(Transaction transaction) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Data\EpiProvider2\EpiConnection.cs:line 209
at Ice.Services.Lib.RunTaskSvcFacade.RunTask(Int64 ipTaskNum) in D:\_Releases\ICE\3.1.500.31\Source\Server\Services\Lib\RunTask\RunTaskSvcFacade.cs:line 87
at SyncInvokeRunTask(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in D:\_Releases\ICE\3.1.500.31\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
