I have had a seperate environment - an Premise - created to test out Kinetic 2022.1.8. I am getting .net runtime errors on the APPserver event viewer for everything I do. I am starting here so I can get all of the questions answered before I try out support.
Error when
Starting task agent from EAC
Logging into Epicor client.
Opening any app within Epicor.
We have been testing Epicor for some time, and everything is working as expected (maybe a bit slower).
My people who created the environment and another consultant helping me are unable to find the problem.
Is there anything that sticks out here? From the appserver event viewer, every error is the same except for the SpanID.
Category: Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware
EventId: 1
SpanId: ed28909b71cf2dbe
TraceId: 3a0fd8bec0066812029474f99636a8ea
ParentId: 0000000000000000
RequestId: 80000c45-0003-f800-b63f-84710c7967bb
RequestPath: /Kinetic2022_1/api/rpc/Ice.BO.GenXData/GetByID
An unhandled exception has occurred while executing the request.
Exception:
Ice.Common.RecordNotFoundException: Record not found.
at Ice.TablesetBound`3.InnerGetByID(IceDataContext dataContext, Int32 pageSize, Int32 absolutePage, Boolean& morePages, TFullTableset tableset, IEnumerable`1 queryParameters) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Framework\Epicor.Ice\Services\TablesetBound.cs:line 704
at Ice.Services.BO.GenXDataSvc.GetByID(String company, String productID, String typeCode, String cgCCode, String key1, String key2, String key3) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Services\BO\GenXData\GenxData.Designer.cs:line 489
at Ice.Services.BO.GenXDataSvcFacade.GetByID(String company, String productID, String typeCode, String cgCCode, String key1, String key2, String key3) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Services\BO\GenXData\GenXDataSvcFacade.cs:line 563
at Ice.Controllers.BO.GenXDataController.GetByID(GetByID_InputModel model) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Services\BO\GenXData\Generated\GenXDataController.cs:line 220
at lambda_method807(Closure , Object , Object[] )
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncObjectResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync()
--- End of stack trace from previous location ---
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Logged|17_1(ResourceInvoker invoker)
at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Ice.Hosting.AspNetCore.Middleware.DynamicAssemblyPartMiddleware.Invoke(HttpContext context, CurrentCallInformationService currentCallInformation, ControllerLoader controllerLoader) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Hosting\AspNetCore\Ice.Hosting.AspNetCore\Middleware\DynamicAssemblyPartMiddleware.cs:line 32
at Ice.Hosting.AspNetCore.Middleware.AuthorizationMiddleware.ProcessAuthenticatedUser(HttpContext context, IPrincipal user) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Hosting\AspNetCore\Ice.Hosting.AspNetCore\Middleware\AuthorizationMiddleware.cs:line 53
at Ice.Hosting.AspNetCore.Middleware.AuthorizationMiddleware.Invoke(HttpContext context, CurrentCallInformationService currentCallInformation) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Hosting\AspNetCore\Ice.Hosting.AspNetCore\Middleware\AuthorizationMiddleware.cs:line 44
at Ice.Hosting.AspNetCore.ETags.ETagMiddleware.Invoke(HttpContext httpContext) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Hosting\AspNetCore\Ice.Hosting.AspNetCore\ETags\ETagMiddleware.cs:line 89
at Ice.Hosting.AspNetCore.ETags.ETagMiddleware.Invoke(HttpContext httpContext) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Hosting\AspNetCore\Ice.Hosting.AspNetCore\ETags\ETagMiddleware.cs:line 107
at Ice.Hosting.AspNetCore.Middleware.DecompressRequestMiddleware.Invoke(HttpContext context) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Hosting\AspNetCore\Ice.Hosting.AspNetCore\Middleware\DecompressRequestMiddleware.cs:line 41
at Epicor.RESTApi.Middleware.ApiKeyEnforcerMiddleware.Invoke(HttpContext context) in C:\_releases\ICE\ICE4.2.100.8\Source\Server\Hosting\AspNetCore\Ice.Hosting.AspNetCore\Middleware\ApiKeyEnforcerMiddleware.cs:line 78
at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware.<Invoke>g__Awaited|6_0(ExceptionHandlerMiddleware middleware, HttpContext context, Task task)
