So I’m trying to work through creating a warehouse bin from from the order entry screen. It’s for a contract bin creation for jobs
I made a button, and have the code to go and check if there is a bin or not. If there isn’t one I want to create one with variables that I have from the order line.
I think I have a new dataset with the GetNewWhseBin code. Now I am trying to figure out how to manipulate the data set before the update and I’m stuck. I need to set the bin number (I have variables for that already) and the description (ditto on the variables). I will be hard coding the bin type as a contract bin. That should be all that I need to set.
When I’m looking in the object explorer for the adapter, I can’t find anything for those columns in the dataset. Should I just be opening the warehouse bin entry screen and looking at the dataview there to get what I need?
Any tips on how to look up the use of the adapters? I have the BL tester pulled up too so I can see the columns on the dataset, but I get stuck on the bridge to connect the dataset to the columns.
I will be doing the same basic thing with the Planning contract adapter as well, but if I can learn how to look up some of this stuff a little better, it should be similar.
WhseBinAdapter BinAdapter = new WhseBinAdapter(oTrans);
BinAdapter.BOConnect();
try
BinAdapter.GetByID("GEN",BinNum); //check if the bin exists
MessageBox.Show("There is a bin " + BinNum);
catch
MessageBox.Show("This bin does not exist");
//get a new bin
BinAdapter.GetNewWhseBin("GEN");
