Hi Rob,
Now I see what I did wrong. I was having trouble declaring the UD08Adapter because I wasn't adding the reference assembly for it. Now I can add the other code you referenced.
Many Thanks!
David Pfiester
Systems Accountant
NuStep Inc.
Phone: 734-769-3939 x150
Many Thanks!
David Pfiester
Systems Accountant
NuStep Inc.
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> I was only able to briefly look at this but you may be missing your ud
> adapter method..
> It might look something like this..
> Dim adaptUD08 As UD08Adapter = New UD08Adapter(ReceiptEntryForm)
> adaptUD08.BOConnect()
> adaptUD08.GetaNewUD06()
> replace receiptentryform with the form name you are working in..
> also don't forget to add your references (tools/assembly reference
> manager)
> Rob Bucek
> Production Control Manager
> PH: (715) 284-5376 ext 311
> Mobile: (715)896-0590
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of nustepvantage
> Sent: Wednesday, September 15, 2010 3:32 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Need Help with VB Code Problem
> Hello All,
> I'm working on a VB procedure where the city, state, and zip fields in
> the customer table are automatically updated when the customer.zip field
> in is changed. The zip, city, and state data are coming from the UD08
> table. The code I have compiles OK, but when I try to run it I get an
> "Object reference not set to an instance of an object" error. I'm new at
> creating VB.Net code, so I'm not sure what I'm doing wrong. I think I'm
> having a problem connecting to UD08 data, but when I try to declare a
> variable to access the data there is a compile error saying UD08 is not
> defined. Here is the code that I have now:
> Private Sub Customer_AfterFieldChange(ByVal sender As object, ByVal args
> As DataColumnChangeEventArgs) Handles Customer_Column.ColumnChanged
> '// ** Argument Properties and Uses **
> '// args.Row("[FieldName]")
> '// args.Column, args.ProposedValue, args.Row
> 'Add Event Handler Code
> Select Case args.Column.ColumnName
> Case "Zip"
> Dim edvCustZip As EpiDataView = CType(oTrans.EpiDataViews("UD08"),
> EpiDataView)
> Dim txtZipCode as Int32 = edvCustZip.dataView(edvCustZip.Row)("Key1")
> Dim txtState as Int32 = edvCustZip.dataView(edvCustZip.Row)("Key2")
> Dim txtCity as Int32 = edvCustZip.dataView(edvCustZip.Row)("Key3")
> Dim edvCustomer As EpiDataView = CType(oTrans.EpiDataViews("Customer"),
> EpiDataView)
> edvCustomer.dataview(edvCustomer.Row)("Zip") = txtZipCode
> edvCustomer.Notify(New EpiNotifyArgs(oTrans, edvCustomer.Row,
> edvCustomer.Column))
> edvCustomer.dataview(edvCustomer.Row)("State") = txtState
> edvCustomer.dataview(edvCustomer.Row)("City") = txtCity
> Case Else
> End Select
> End Sub
> If anyone could point me in the right direction I would really
> appreciate it. We are currently running Vantage 406A.
> Thanks,
> David Pfiester
> Systems Accountant
> NuStep Inc.
