Need help with adding additional table to Job Traveler in Crysta
And check the XML file to see if the PartBin table is shown in the XML...If so, does it have data in the xml for PartBin?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cooner_55421
Sent: Friday, June 10, 2011 12:53 PM
Subject: [Vantage] Re: Need help with adding additional table to Job Traveler in Crystal
Some things to check -
You ran a report
--- the report style used the new RDD
Then opened the report specified in the style in Crystal
- and you are sure you changed the db connection to the XML file that was created when you ran the report? They are usually stored in a folder on the server, something like this -
\\servername\epicorshare\EpicorData\Reports\your_user_name
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Bethany Rye" <brye@...> wrote:
> I've done all of this and the PartBin table still isn't showing. Something
> I missed?
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> cooner_55421
> Sent: Wednesday, June 08, 2011 4:29 PM
> Traveler in Crystal
> Oh yeah.... A couple more steps will be required.
> In Crystal, now that you're linked to the new XML,
> Open Database Expert.
> Expand "Current Connections"
> You should see the table.
> Click the arrow to move it to selected tables.
> Then make sure you click the links tab and check/add the joins.
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "Bethany
> Rye" <brye@> wrote:
> > We did all this and still cannot see the added table, PartBin.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > cooner_55421
> > Sent: Wednesday, June 08, 2011 2:56 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > Traveler in Crystal
> > You changed the report style too?
> > If so...
> > Then bear with me... here is a general outline of the steps.
> > (there are multiple ways to set this, and it's pretty hard to explain
> > without screen shots)
> > Run the report from the menu.
> > Then open the report in Crystal.
> > In Field Explorer, right click on Database Fields, select set datasource
> > location.
> > Expand the report properties
> > double click on the file path & wipe it & close.
> > A dialog box will pop up and let you browse out to you report data
> directory
> > and select the new XML you generated when yo ran the report.
> > Rye" <brye@> wrote:
> > > OK. We did that. So how do we get the Crystal Report to recognize the
> new
> > > RDD?
> > > Beth
> > Behalf Of
> > > cooner_55421
> > > Sent: Wednesday, June 08, 2011 2:30 PM
> > > Traveler in Crystal
> > > Yes, you won't be able to modify system RDDs.
> > > Duplicate it and modify the new copy.
> > > Then on your report style, specify the new RDD.
> > > Rye" <brye@> wrote:
> > > > I found the Report Data Definitions and went to the report (Job
> > Traveler).
> > > > I'm able to look at it, but I can't add a table. The option for it is
> > > > greyed out. I'm thinking it is greyed out because it is a system
> report.
> > > > Am I correct?
> > > > Beth Rye
> > > > IT Director
> > > > CIGNYS
> > > > 68 Williamson Street
> > > > Saginaw, Michigan 48601
> > > > Phone: (989) 753-1411 ext. 1114
> > > > Direct Line: (989) 393-0108
> > > > Fax: (989) 393-0208
> > > > Email: brye@
> > > > ***ITAR NOTICE***
> > > > This e-mail and/or the attached documents may contain technical data
> > > within
> > > > the definition of the International Traffic in Arms regulations, and
> are
> > > > subject to the export control laws of the US Government. Transfer of
> > this
> > > > data by any means to a foreign person, whether in the US or abroad,
> > > without
> > > > an export license or other approval from the US Department of State,
> is
> > > > prohibited. No portion of this e-mail or its attachment(s) may be
> > > reproduced
> > > > without written consent of CIGNYS. If you are not the intended
> recipient
> > > or
> > > > believe that you may have received this document in error, please
> notify
> > > the
> > > > sender and delete this e-mail and any attachments immediately.
> > > > -----Original Message-----
> > > Behalf Of
> > > > Waffqle
> > > > Sent: Wednesday, June 08, 2011 1:34 PM
> > > > Subject: Re: [Vantage] Need help with adding additional table to Job
> > > > Traveler in Crystal
> > > > "Report Data Definitions" are what you want.
> > > > They're under System > Company Maintenance.
> > > > They're a little wierd at first but you should be able to get the hang
> > of
> > > it
> > > > pretty quick. Let me know if you have any issues once you get in
> there.
> > > > On Wed, Jun 8, 2011 at 12:13 PM, Bethany Rye <brye@> wrote:
> > > > > I'm trying to link the PartBin table into the existing Job Traveler
> so
> > > > > that I can print the bin number of the raw materials. I have tried
> > > > > adding the table through an ODBC connection but then the subreport
> > > > > goes blank and none of the raw materials will display. What I need
> to
> > > > > know is how to add a table to an existing Epicor report. Any help
> > would
> > > be
> > > > greatly appreciated!
> > > > > Beth
> > > > > Beth Rye
> > > > > IT Director
> > > > > CIGNYS
> > > > > Email: <mailto:brye@> brye@
> > > > > ***ITAR NOTICE***
> > > > > within the definition of the International Traffic in Arms
> > > > > regulations, and are subject to the export control laws of the US
> > > > > Government. Transfer of this data by any means to a foreign person,
> > > > > whether in the US or abroad, without an export license or other
> > > > > approval from the US Department of State, is prohibited. No portion
> of
> > > > > this e-mail or its attachment(s) may be reproduced without written
> > > > > consent of CIGNYS. If you are not the intended recipient or believe
> > > > > that you may have received this document in error, please notify the
> > > > > [Non-text portions of this message have been removed]
> > > > *Waffqle Driggers*
> > > > *High End Dev, System Design, Profit Drinking
> > > > *:: 904.962.2887*
> > > > *:: waffqle@*
> > > > *:: NO FAXES*
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> > > > already linked your email address to a yahoo id to enable access. )
> > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > > Crystal Reports and other 'goodies', please goto:
> > > > http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > > > (2) To search through old msg's goto:
> > > > http://groups.yahoo.com/group/vantage/messages
> > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
I'm trying to link the PartBin table into the existing Job Traveler so that
I can print the bin number of the raw materials. I have tried adding the
table through an ODBC connection but then the subreport goes blank and none
of the raw materials will display. What I need to know is how to add a
table to an existing Epicor report. Any help would be greatly appreciated!
Beth
Beth Rye
IT Director
CIGNYS
Email: <mailto:brye@...> brye@...
***ITAR NOTICE***
This e-mail and/or the attached documents may contain technical data within
the definition of the International Traffic in Arms regulations, and are
subject to the export control laws of the US Government. Transfer of this
data by any means to a foreign person, whether in the US or abroad, without
an export license or other approval from the US Department of State, is
prohibited. No portion of this e-mail or its attachment(s) may be reproduced
without written consent of CIGNYS. If you are not the intended recipient or
believe that you may have received this document in error, please notify the
They're a little wierd at first but you should be able to get the hang of it
pretty quick. Let me know if you have any issues once you get in there.
> Beth
> Beth Rye
> IT Director
> CIGNYS
> ***ITAR NOTICE***
> reproduced
> the
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Hi Beth,
This is what I have setup in the report data defenitions:
Relation: JobMatPartBin
Description: JobMat to PartBin
Parent Table: JobMtl
Child Table: PartBin
The fields that I'm using are:
Company
PartNum
WarehouseCode
Does this get you the information that you need?
Travis Late
IT/ERP Manager
M-B Companies, Inc
Office: 920-898-1560 Ext. 264
Mobile: 920-960-0062
tlate@... <mailto:tlate@...>
Of Bethany Rye
Sent: Wednesday, June 08, 2011 11:14 AM
Subject: [Vantage] Need help with adding additional table to Job
Traveler in Crystal
that
none
appreciated!
Beth
Beth Rye
IT Director
CIGNYS
Email: <mailto:brye@... <mailto:brye%40cignys.com> >
***ITAR NOTICE***
within
this
without
reproduced
or
the
M-B Companies Confidentiality Notice:
This message is being sent by M-B Companies. It is intended exclusively for
the individuals and entities to which it is addressed. This communication,
including any attachments, may contain information that is proprietary,
privileged and confidential if you are not the named addressee; you are not
authorized to read,print,retain copy or disseminate this message or any part
of it.If you have received this message in error, please notify the sender
immediately by email.
I found the Report Data Definitions and went to the report (Job Traveler).
greyed out. I'm thinking it is greyed out because it is a system report.
Am I correct?
Beth Rye
IT Director
CIGNYS
Phone:Â (989) 753-1411Â ext. 1114
Fax:Â (989) 393-0208
Email:Â brye@...
***ITAR NOTICE***
Waffqle
Traveler in Crystal
> goes blank and none of the raw materials will display. What I need to
> know is how to add a table to an existing Epicor report. Any help would be
> Beth
> Beth Rye
> IT Director
> CIGNYS
> ***ITAR NOTICE***
> approval from the US Department of State, is prohibited. No portion of
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
OK. We did that. So how do we get the Crystal Report to recognize the new
RDD?
Beth
cooner_55421
Traveler in Crystal
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Bethany
> Am I correct?
> Beth Rye
> IT Director
> CIGNYS
> Fax: (989) 393-0208
> Email: brye@...
> ***ITAR NOTICE***
within
without
reproduced
or
the
Behalf Of
> Waffqle
> Traveler in Crystal
it
be
> > Beth
> > Beth Rye
> > IT Director
> > CIGNYS
> > ***ITAR NOTICE***
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
cooner_55421
Traveler in Crystal
If so...
location.
A dialog box will pop up and let you browse out to you report data directory
> RDD?
> Beth
Behalf Of
> cooner_55421
> Traveler in Crystal
Traveler).
> > Am I correct?
> > Beth Rye
> > IT Director
> > CIGNYS
> > Fax: (989) 393-0208
> > Email: brye@
> > ***ITAR NOTICE***
> within
this
> without
> reproduced
> or
> the
> Behalf Of
> > Waffqle
> > Traveler in Crystal
of
> it
would
> be
> > > Beth
> > > Beth Rye
> > > IT Director
> > > CIGNYS
> > > ***ITAR NOTICE***
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@*
> > *:: NO FAXES*
have
and
Absolutely. You have to copy it. (Action) Then you can add a table.
Then set any old report that uses the old DLL to use the new DLL, run the report so it generates a XML file. The go to Crystal and connect to this new XML.
But don't forget even if you make the relationships between old tables and new tables in the DLL, you have to repeat them in Crystal.
> Am I correct?
> Beth Rye
> IT Director
> CIGNYS
> Email:Â brye@...
> ***ITAR NOTICE***
> Waffqle
> Traveler in Crystal
> > Beth
> > Beth Rye
> > IT Director
> > CIGNYS
> > ***ITAR NOTICE***
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
I missed?
cooner_55421
Traveler in Crystal
Behalf Of
> cooner_55421
> Traveler in Crystal
> If so...
> location.
directory
new
> > RDD?
> > Beth
> Behalf Of
> > cooner_55421
> > Traveler in Crystal
> Traveler).
report.
> > > Am I correct?
> > > Beth Rye
> > > IT Director
> > > CIGNYS
> > > Fax: (989) 393-0208
> > > Email: brye@
> > > ***ITAR NOTICE***
> > within
are
> this
> > without
is
> > reproduced
recipient
> > or
notify
> > the
> > Behalf Of
> > > Waffqle
> > > Traveler in Crystal
> of
> > it
there.
so
to
> would
> > be
> > > > Beth
> > > > Beth Rye
> > > > IT Director
> > > > CIGNYS
> > > > ***ITAR NOTICE***
of
> > > *Waffqle Driggers*
> > > *:: 904.962.2887*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> have
> and
I missed?
cooner_55421
Traveler in Crystal
Behalf Of
> cooner_55421
> Traveler in Crystal
> If so...
> location.
directory
new
> > RDD?
> > Beth
> Behalf Of
> > cooner_55421
> > Traveler in Crystal
> Traveler).
report.
> > > Am I correct?
> > > Beth Rye
> > > IT Director
> > > CIGNYS
> > > Fax: (989) 393-0208
> > > Email: brye@
> > > ***ITAR NOTICE***
> > within
are
> this
> > without
is
> > reproduced
recipient
> > or
notify
> > the
> > Behalf Of
> > > Waffqle
> > > Traveler in Crystal
> of
> > it
there.
so
to
> would
> > be
> > > > Beth
> > > > Beth Rye
> > > > IT Director
> > > > CIGNYS
> > > > ***ITAR NOTICE***
of
> > > *Waffqle Driggers*
> > > *:: 904.962.2887*
> > > *:: waffqle@*
> > > *:: NO FAXES*
> have
> and
