Need help updating customisation code
Hi everyone,
I have been asked to update a customisation that was done on our Project Entry (Not by Me).
We have a grid as pictured below, where I have been asked to add a column displaying the TerritoryID. As you can see I have done the easy bit by adding the column but I don’t how to edit the code to actually populate it with the TerritoryID. Can any customisation experts help me?
Here is the code;
// Custom code for ProjectEntryForm
// Created: 26/04/2017 14:28:07
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinGrid;
public class Script
	private UD20Adapter _ud20Adapter;
	private EpiDataView _edvProject;
	private DataTable UD20_Column;
	private EpiDataView _edvUD20;
	private string _Key1UD20;
	private string _Key2UD20;
	private string _Key3UD20;
	private string _Key4UD20;
	private string _Key5UD20;
	private DataView Project_DataView;
		InitializeUD20Adapter();
		this._Key1UD20 = string.Empty;
		this._Key2UD20 = string.Empty;
		this._Key3UD20 = string.Empty;
		this._Key4UD20 = string.Empty;
		this._Key5UD20 = string.Empty;
		this.baseToolbarsManager.ToolClick += new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClickForUD20);
		this.ProjectEntryForm.BeforeToolClick += new Ice.Lib.Framework.BeforeToolClickEventHandler(this.ProjectEntryForm_BeforeToolClickForUD20);
		this.ProjectEntryForm.AfterToolClick += new Ice.Lib.Framework.AfterToolClickEventHandler(this.ProjectEntryForm_AfterToolClickForUD20);
		this.Project_Row.EpiRowChanged += new EpiRowChanged(this.Project_AfterRowChangeForUD20);
		this.Project_DataView = this.Project_Row.dataView;
		this.Project_DataView.ListChanged += new ListChangedEventHandler(this.Project_DataView_ListChangedForUD20);
		this.UD20_Column.ColumnChanged += new DataColumnChangeEventHandler(this.UD20_AfterFieldChange);
		SetExtendedProperties();
		if ((this._ud20Adapter != null))
			this._ud20Adapter.Dispose();
			this._ud20Adapter = null;
		this._edvUD20 = null;
		this._edvProject = null;
		this.UD20_Column = null;
		this._Key1UD20 = null;
		this._Key2UD20 = null;
		this._Key3UD20 = null;
		this._Key4UD20 = null;
		this._Key5UD20 = null;
		this.baseToolbarsManager.ToolClick -= new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClickForUD20);
		this.ProjectEntryForm.BeforeToolClick -= new Ice.Lib.Framework.BeforeToolClickEventHandler(this.ProjectEntryForm_BeforeToolClickForUD20);
		this.ProjectEntryForm.AfterToolClick -= new Ice.Lib.Framework.AfterToolClickEventHandler(this.ProjectEntryForm_AfterToolClickForUD20);
		this.Project_Row.EpiRowChanged -= new EpiRowChanged(this.Project_AfterRowChangeForUD20);
		this.Project_DataView.ListChanged -= new ListChangedEventHandler(this.Project_DataView_ListChangedForUD20);
		this.Project_DataView = null;
		this.UD20_Column.ColumnChanged -= new DataColumnChangeEventHandler(this.UD20_AfterFieldChange);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private void SearchOnCountryAdapterFillDropDown()
		// Wizard Generated Search Method
		// You will need to call this method from another method in custom code
		// For example, [Form]_Load or [Button]_Click
		bool recSelected;
		string whereClause = string.Empty;
		System.Data.DataSet dsCountryAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "CountryAdapter", out recSelected, false, whereClause);
		if (recSelected)
			// Set EpiUltraCombo Properties
			this.CountryCmb.ValueMember = "CountryNum";
			this.CountryCmb.DataSource = dsCountryAdapter;
			this.CountryCmb.DisplayMember = "Description";
			string[] fields = new string[] {
					"Description"};
			this.CountryCmb.SetColumnFilter(fields);
	private void ProjectEntryForm_Load(object sender, EventArgs args)
		// Add Event Handler Code
		EpiUltraGrid projCustGrid = ((EpiUltraGrid)csm.GetNativeControlReference("443cbd92-c1f6-4848-a739-7588302d4e3e"));
		UltraGridBand projCustGridBand = projCustGrid.DisplayLayout.Bands[0];
		projCustGridBand.Columns["Number01"].ValueList = baqCustNum;
		projCustGridBand.Columns["Number01"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
		projCustGridBand.Columns["ShortChar01"].ValueList = CustTypeCmb;
		projCustGridBand.Columns["ShortChar01"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
		CountryCmb.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
		SalesRepTxt.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
		SearchOnCountryAdapterFillDropDown();
		SearchOnSalesRepAdapterFillDropDown();
	private void SearchOnSalesRepAdapterFillDropDown()
		bool recSelected;
		System.Data.DataSet dsSalesRepAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "SalesRepAdapter", out recSelected, false, whereClause);
		if (recSelected)
			this.SalesRepTxt.ValueMember = "SalesRepCode";
			this.SalesRepTxt.DataSource = dsSalesRepAdapter;
			this.SalesRepTxt.DisplayMember = "Name";
					"Name"};
			this.SalesRepTxt.SetColumnFilter(fields);
	private void InitializeUD20Adapter()
		// Create an instance of the Adapter.
		this._ud20Adapter = new UD20Adapter(this.oTrans);
		this._ud20Adapter.BOConnect();
		// Add Adapter Table to List of Views
		// This allows you to bind controls to the custom UD Table
		this._edvUD20 = new EpiDataView();
		this._edvUD20.dataView = new DataView(this._ud20Adapter.UD20Data.UD20);
		this._edvUD20.AddEnabled = true;
		//this._edvUD20.AddText = "New UD20";
		this._edvUD20.AddText = "New Project Customer";
		if ((this.oTrans.EpiDataViews.ContainsKey("UD20View") == false))
			this.oTrans.Add("UD20View", this._edvUD20);
		// Initialize DataTable variable
		this.UD20_Column = this._ud20Adapter.UD20Data.UD20;
		// Initialize EpiDataView field.
		this._edvProject = ((EpiDataView)(this.oTrans.EpiDataViews["Project"]));
		// Set the parent view / keys for UD child view
		string[] parentKeyFields = new string[1];
		string[] childKeyFields = new string[1];
		parentKeyFields[0] = "ProjectID";
		childKeyFields[0] = "Key1";
		this._edvUD20.SetParentView(this._edvProject, parentKeyFields, childKeyFields);
		if ((this.oTrans.PrimaryAdapter != null))
			// this.oTrans.PrimaryAdapter.GetCurrentDataSet(Ice.Lib.Searches.DataSetMode.RowsDataSet).Tables.Add(this._edvUD20.dataView.Table.Clone())
	private void GetUD20Data(string key1, string key2, string key3, string key4, string key5)
		if ((this._Key1UD20 != key1) || (this._Key2UD20 != key2) || (this._Key3UD20 != key3) || (this._Key4UD20 != key4) || (this._Key5UD20 != key5))
			// Build where clause for search.
			string whereClause = "Key1 = \'" + key1 + "\' And Key2 = \'" + key2 + "\' And Key3 = \'" + key3 + "\' And Key4 = \'" + key4 + "\'";
			System.Collections.Hashtable whereClauses = new System.Collections.Hashtable(1);
			whereClauses.Add("UD20", whereClause);
			// Call the adapter search.
			SearchOptions searchOptions = SearchOptions.CreateRuntimeSearch(whereClauses, DataSetMode.RowsDataSet);
			this._ud20Adapter.InvokeSearch(searchOptions);
			if ((this._ud20Adapter.UD20Data.UD20.Rows.Count > 0))
				this._edvUD20.Row = 0;
			} else
				this._edvUD20.Row = -1;
			// Notify that data was updated.
			this._edvUD20.Notify(new EpiNotifyArgs(this.oTrans, this._edvUD20.Row, this._edvUD20.Column));
			// Set key fields to their new values.
			this._Key1UD20 = key1;
			this._Key2UD20 = key2;
			this._Key3UD20 = key3;
			this._Key4UD20 = key4;
			this._Key5UD20 = key5;
	private void GetNewUD20Record()
		DataRow parentViewRow = this._edvProject.CurrentDataRow;
		// Check for existence of Parent Row.
		if ((parentViewRow == null))
			return;
		else
			oTrans.Update();
		if (this._ud20Adapter.GetaNewUD20())
			string projectid = parentViewRow["ProjectID"].ToString();
			// Get unique row count id for Key5
			int rowCount = this._ud20Adapter.UD20Data.UD20.Rows.Count;
			int lineNum = rowCount;
			bool goodIndex = false;
			while ((goodIndex == false))
				// Check to see if index exists
				DataRow[] matchingRows = this._ud20Adapter.UD20Data.UD20.Select("Key5 = \'" + lineNum.ToString() + "\'");
				if ((matchingRows.Length > 0))
					lineNum = (lineNum + 1);
				} else
					goodIndex = true;
			// Set initial UD Key values
			DataRow editRow = this._ud20Adapter.UD20Data.UD20.Rows[(rowCount - 1)];
			editRow.BeginEdit();
			editRow["Key1"] = projectid;
			editRow["Key2"] = string.Empty;
			editRow["Key3"] = string.Empty;
			editRow["Key4"] = string.Empty;
			editRow["Key5"] = lineNum.ToString();
			editRow.EndEdit();
			this._edvUD20.Notify(new EpiNotifyArgs(this.oTrans, (rowCount - 1), this._edvUD20.Column));
	private void SaveUD20Record()
		// Save adapter data
		this._ud20Adapter.Update();
	private void DeleteUD20Record()
		// Check to see if deleted view is ancestor view
		bool isAncestorView = false;
		Ice.Lib.Framework.EpiDataView parView = this._edvUD20.ParentView;
		while ((parView != null))
			if ((this.oTrans.LastView == parView))
				isAncestorView = true;
				break;
			} else
				parView = parView.ParentView;
		// If Ancestor View then delete all child rows
		if (isAncestorView)
			DataRow[] drsDeleted = this._ud20Adapter.UD20Data.UD20.Select("Key1 = \'" + this._Key1UD20 + "\' AND Key2 = \'" + this._Key2UD20 + "\' AND Key3 = \'" + this._Key3UD20 + "\' AND Key4 = \'" + this._Key4UD20 + "\'");
			for (int i = 0; (i < drsDeleted.Length); i = (i + 1))
				this._ud20Adapter.Delete(drsDeleted[i]);
		}/* else
MessageBox.Show("processing for not ancestor");
			if ((this.oTrans.LastView == this._edvUD20))
MessageBox.Show("in 1");
				if ((this._edvUD20.Row >= 0))
MessageBox.Show("in 2");
					DataRow drDeleted = ((DataRow)(this._ud20Adapter.UD20Data.UD20.Rows[this._edvUD20.Row]));
					if ((drDeleted != null))
MessageBox.Show("in 3");
						if (this._ud20Adapter.Delete(drDeleted))
MessageBox.Show("in 4");
							if ((_edvUD20.Row > 0))
MessageBox.Show("in 5");
								_edvUD20.Row = (_edvUD20.Row - 1);
MessageBox.Show("before notify");
MessageBox.Show("after notify");
	private void UndoUD20Changes()
		this._ud20Adapter.UD20Data.RejectChanges();
	private void ClearUD20Data()
		this._ud20Adapter.UD20Data.Clear();
	private void baseToolbarsManager_ToolClickForUD20(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs args)
		// EpiMessageBox.Show(args.Tool.Key);
		switch (args.Tool.Key)
			case "EpiAddNewNew Project Customer":
				GetNewUD20Record();
				break;
			case "ClearTool":
				ClearUD20Data();
				break;
			case "UndoTool":
				UndoUD20Changes();
				break;
	private void ProjectEntryForm_BeforeToolClickForUD20(object sender, Ice.Lib.Framework.BeforeToolClickEventArgs args)
			case "SaveTool":
				SaveUD20Record();
				break;
			case "DeleteTool":
				DeleteUD20RecordBefore();
				break;
	private void ProjectEntryForm_AfterToolClickForUD20(object sender, Ice.Lib.Framework.AfterToolClickEventArgs args)
			case "DeleteTool":
				if ((args.Cancelled == false))
					DeleteUD20Record();
				oTrans.Refresh();
				break;
	private void Project_AfterRowChangeForUD20(EpiRowChangedArgs args)
		// ** add AfterRowChange event handler
		string projectid = args.CurrentView.dataView[args.CurrentRow]["ProjectID"].ToString();
		GetUD20Data(projectid, string.Empty, string.Empty, string.Empty, string.Empty);
	private void Project_DataView_ListChangedForUD20(object sender, ListChangedEventArgs args)
		// ** add ListChanged event handler
		string projectid = Project_DataView[0]["ProjectID"].ToString();
	private void SetExtendedProperties()
		// Begin Wizard Added EpiDataView Initialization
		EpiDataView edvUD20View = ((EpiDataView)(this.oTrans.EpiDataViews["UD20View"]));
		// End Wizard Added EpiDataView Initialization
		// Begin Wizard Added Conditional Block
		if (edvUD20View.dataView.Table.Columns.Contains("Character01"))
			// Begin Wizard Added ExtendedProperty Settings: edvUD20View-ShortChar01
			edvUD20View.dataView.Table.Columns["Character01"].ExtendedProperties["ReadOnly"] = true;
			// End Wizard Added ExtendedProperty Settings: edvUD20View-ShortChar01
		// End Wizard Added Conditional Block
	private void UD20_AfterFieldChange(object sender, DataColumnChangeEventArgs args)
		// args.Row["FieldName"]
		// args.Column, args.ProposedValue, args.Row
		switch (args.Column.ColumnName)
			case "Number01":
				SearchOnCustomerAdapterNoShowDialog();
				break;
	private void SearchOnCustomerAdapterNoShowDialog()
		bool recSelected;
		System.Data.DataRow edvUD20ViewRow = edvUD20View.CurrentDataRow;
		if ((edvUD20ViewRow != null))
			whereClause = "CustNum = " + Convert.ToInt32(edvUD20ViewRow["Number01"]);
			System.Data.DataSet dsCustomerAdapter = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "CustomerAdapter", out recSelected, false, whereClause);
			if (recSelected)
				System.Data.DataRow adapterRow = dsCustomerAdapter.Tables[0].Rows[0];
			// Map Search Fields to Application Fields
				edvUD20ViewRow.BeginEdit();
				edvUD20ViewRow["Character01"] = adapterRow["Name"];
				edvUD20ViewRow.EndEdit();
	private void DeleteUD20RecordBefore()
				break;
			} else
		if (!isAncestorView)
oTrans.Refresh();
Best regards
Adrian
I don’t have my stuff with me, so I can’t tell if TerritoryID is in Customer Table. BUT IF SO, add a second line just under this
edvUD20ViewRow[“Character01”] = adapterRow[“Name”];
in order to have:
edvUD20ViewRow[“YourUDFieldUsedForTerritory”] = adapterRow[“TerritoryIDOrSomethinglikeIt”];
Suggestion:
find this line in the code:
edvUD20View.dataView.Table.Columns[“Character01”].ExtendedProperties[“ReadOnly”] = true;
and add
edvUD20View.dataView.Table.Columns[“YourUDFieldUsedForTerritory”].ExtendedProperties[“ReadOnly”] = true;
unless you want it to be updatable in UD20.
Hi Louis,
Thank you so much for the help. I have added the lines as you suggested and the code compiles with no errors. The ReadOnly part is working but the column has no TerritoryID in it.
