Thanks Ted. I'll give this a try.
Dale
_____
Ted Koch
Sent: Thursday, September 29, 2011 4:29 PM
Subject: Re: [Vantage] Need code for button to launch Quick Search or Named
Search
Try this. It will launch a customer search. Change "Name" to whatever field
in Customer you want to save to a variable.
Dim FileName as string
Dim opts as new
SearchOptions(Epicor.Mfg.UI.Searches.SearchMode.ShowDialog)
opts.DataSetMode = DataSetMode.ListDataSet
Dim callResult As Object =
ProcessCaller.LaunchSearch(POSuggEntryForm, "CustomerAdapter", opts)
If(TypeOf callResult Is System.Data.DataSet) AndAlso
(DirectCast(callResult, DataSet).Tables(0).Rows.Count > 0) Then
FileName = callResult.Tables(0).Rows(0).Item("Name")
End if
<mailto:daled%40completehomeconcepts.com> >
Sent: Thursday, September 29, 2011 5:10 PM
Subject: [Vantage] Need code for button to launch Quick Search or Named
Search
Has anyone figured out how to launch a Quick Search or Named Search from an
epibutton that would be willing to share their code???
Our users needed a way to search customers by customer address. My solution;
build a Quick Search that allows users to search by customer address, ship
to address, or customer name. Now I would like to take it a step further and
make accessing it a little more convenient by adding a button on the
customer tracker and customer detail views that launches the quick search
form. I found a UI object in ProcessCaller methods for namedsearches
(ProcessCaller.LaunchNamedSearchForm) but it doesn't work and unsuccessful
so far using other "launch form" UI's.
Thanks in advance for any help or suggestions.
Best regards,
Dale Dalton
Complete Home Concepts
Dale
_____
Ted Koch
Search
Dim opts as new
End if
Search
Best regards,
Dale Dalton
