This is exactly what I ended up doing. As of this morning we are live on
5.1.10 and so far so good. Touch wood.......
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
Winnipeg, MB R3H 0C4
http://www.neon-products.com/
mailto:
rnewell@...
michael.podlin@...]
Sent: Monday, December 10, 2001 11:30 AM
To:
vantage@yahoogroups.com
Subject: RE: [Vantage] My own 5.1 frustrations - cv/cvxa0047.p hangs on data
conversion
I too found this error. I had walked through the conversions several times
with everything all timed out to the minute. With the last time I tried to
bring the data across, I got hung in the same spot. What I have found is
that there seems to be a problem with the Vantage 107 and Progress 10
revisions. What I have found to work is to setup the 5.1 server to Vantage
106 patch and Progress to the 7 patch. After bringing the data across, then
install the Progress 10 and the latest Vantage 107+ patch. This seems to
work very well. (tested on 4 complete trial conversions 3 to 5.1, will be
doing the actual live conversion over the Christmas week. All told, the
time works out to about 3 1/2 days.) I hope this information helps.
Michael Podlin
rnewell@...]
Sent: Sunday, December 09, 2001 10:36 AM
To:
Has any one else run into a problem with "Program: cv/cvxa0047.p" when
doing the 5.1 database conversion? I just hung here also.
Ron Newell
IT/MIS
Neon Products
1695 Sargent Ave.
mailto:
rnewell@...
rspriggle@...]
Sent: Thursday, December 06, 2001 8:25 AM
To:
Subject: [Vantage] My own 5.1 frustrations
I'm in the process of doing a 3.0 to 5.1 upgrade on our test server and I've
run in to some problems. Thought I would throw them out here and see what
everyone thinks.
I've successfully gotten to 5.0, this being the third successful upgrade to
5.0 on our test server. For 5.1 the schema changes, although they took 8+
hours for a 1.5gb database, went through fine with no errors. I started the
db conversions yesterday about this time and had some errors plus now it is
hung on the same process for over 18 hours.
Here are the errors:
1. Program: cv/cves0001.p
Description: Initialize new shop load fields
Message: Updating shopload table
Error: No WrkCenter -0 record is available (91)
Occurances: 20
2. Program: cv/cvxa0043.p
Description: Fix bad partbin quantities
Error: No Whsebin record is available (91)
Occurances: 37
Now it is hung on this:
Description: Reverse PartTran for shipdtl records which are not
shipped
Message: Reversing extra parttran records
We did not do a dump and load, did not close jobs, did not close financials,
etc. I just did a db copy from each version to the next, ran the schema
changes, then the db conversions. The workstation I'm using is W98 so I
can't see any activity and only know that progress is still responding. The
server is pretty much idle at 97% and shows an occasional 1-3% usage on
_mprosrv.exe. Crash protection is turned off. My guess is this is hung and
I'm starting over again.
Any suggestions?
Rick
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
