Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Monday, July 21, 2014 12:40 PM
To: vantage
Subject: Re: [Vantage] Multiple Table Update on an Updateable Dashboard
Thanks Rob, not sure why I didn't remember that you can update multiple as long as they show in the tree view. We were able to update QuoteHed & QuoteDtl together. We then cheated on the Task and put it as a separate panel in the same dashboard.
On Fri, Jul 18, 2014 at 12:27 PM, Rob Bucek rbucek@...<mailto:rbucek@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Ken,
I have updateable BAQ’s updating multiple tables. I have them doing it one of two ways depending on the tree structure brought in by the business object chosen under the Update Processing tab. If the tables you want are all associated as parent children in the tree structure you can update any of those tables assuming you meet business logic rules that are in place for the given fields you are trying to modify. If your table structure isn’t a natural join or you are attempting to update data and need to circumvent BL, then advanced BPM processing is your friend.
Rob Bucek
PH: (715) 284-5376 ext 311<tel:%28715%29%20284-5376%20ext%20311>
Mobile: (715)896-3119<tel:%28715%29896-3119>
FAX: (715)284-4084<tel:%28715%29284-4084>
[cid:1.234354861@...<mailto:cid%3A1.234354861@...>]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
Sent: Friday, July 18, 2014 11:08 AM
To: vantage
Subject: [Vantage] Multiple Table Update on an Updateable Dashboard
Is there any method for being able to update multiple tables from a single BAQ?
We've got a Quote Dashboard we've created, we'd like to be able to update QuoteHed, QuoteDtl & Task fields from this dashboard. Is it possible?
