Hi guys - My head is spinning trying to understand how to set up the Multi-company Translations in External Company Maintenance. (lives in the Ice.IntTransIn table, I think).
Do I make my receiving company (Company B) the current company, and select the parent Company A in External Company Maintenance for the translation? The help file states the translation must be on the receiving company in External Company Maintenance (child company B current). However, KB0040422 shows it as the exporting company (parent company A current).
Is Inbound what is coming in from the external parent company A and database what is getting replaced in child-receiving Company B (per help), or is it the other way (per KB article)?
Help - Translations Topic:
Translations are used to remap from an incoming transaction from the external company (Inbound Value) into the current company (Database Value). The Default Value is used to specify if none is provided from the inbound document or no mapping exists.
The “Database value” field there you have to put the value you will receive.
The “Inbound Value” field there you have to put the value that will replace the one going in.
Snip…
On the Parent External Company Maintenance, when setting the translation for the Child Company (EPIC02), for Table = Part and Field = Class ID, you have to use as follow
- Database Value = HDW (Class ID value on Child Company database)
- Inbound Value = AKB (Class ID value on Parent Company to be used)
““So when the part goes in, if AKB comes up it will be replaced by HDW””
