Multi tasking of direct labor employees
sorry. One operator may begin the day on one job, a couple of hours later he
might begin another job in the same work center, different machine....ALWAYS
a different machine. After two hours he stops job #2 and finish his eight
hours on job #1. This gives him 7 hours on job 1 and 1 hour on job 2 as we
are splitting direct hours. The efficiencies are measured against how many
parts SHOULD have been produced in 2 hours (earned hours) although he
actually only worked on that one job for one hour, thus a 50% efficiency is
actually 100%. I could handle it if this was as complex as it gets, but
juggling several jobs, splitting 37 minutes over four jobs and 58 minutes
over 5 jobs then stopping one of them and then distributing time over the
remaining four....... Sheesh! It can be a nightmare.
> -----Original Message-----
> From: Todd Anderson [SMTP:tanderson@...]
> Sent: Friday, October 27, 2000 12:52 PM
> To: 'vantage@egroups.com'
> Subject: RE: [Vantage] multi tasking of direct labor employees
> Mark,
> Can you be more specific ... What do you mean by "Multi-Tasking".
> Is this one operator running 1 or more machines at a time or one operator
> running more than 1 job concurrently on the same machine or ... ?
> Todd Anderson
> From: Wesley, Mark (DRI) [mailto:MarkW@...]
> Sent: Friday, October 27, 2000 12:21 PM
> To: vantage@egroups.com
> Subject: [Vantage] multi tasking of direct labor employees
> I read daily and see a number of technical issues in this forum but often
> times, there is little response to issues regarding actual application of
> the tools that Vantage offers. Our company is currently experiencing such
> a
> problem and to date, Vantage support has not been able to give much help.
> I
> would think it is a common problem so I'd like to throw it out here,
> hoping
> that someone has a "work-around" solution. We have direct labor
> "multi-tasking" at times, while they are dedicated to one specific
> operation
> at other times. This is creating major headaches with efficiencies on
> labor
> edit reports (and other places) due to the splitting of direct hours and
> the
> use of "earned" hours for these efficiencies. Maybe I'm missing a key
> ingredient here but I'm hoping someone has encountered and resolved this
> problem and can either knock some sense into me or at least offer some
> sound
> resolution.
> Thanks.
> Mark Wesley
> DRI/Primex
> 256-835-1660 X367
> eGroups Sponsor
> <http://click.egroups.com/1/9667/13/_/411782/_/972667424/>
> <http://adimg.egroups.com/img/9667/13/_/411782/_/972667424/WarningToys468x
> 60
> 2E.gif>
> We no longer allow attachments to files. To access/share Report Files,
> please go to the following link: http://www.egroups.com/files/vantage/
> <http://www.egroups.com/files/vantage/>
> (Note: If this link does not work for you the first time you try it, go
> to
> www.egroups.com, login and be sure to save your password, choose My
> Groups,
> choose Vantage, then choose Files. If you save the password, the link
> above
> will work the next time you try it.)
> to www.egroups.com, login and be sure to save your password, choose My
> Groups, choose Vantage, then choose Files. If you save the password, the
> link above will work the next time you try it.)
the tools that Vantage offers. Our company is currently experiencing such a
problem and to date, Vantage support has not been able to give much help. I
would think it is a common problem so I'd like to throw it out here, hoping
"multi-tasking" at times, while they are dedicated to one specific operation
at other times. This is creating major headaches with efficiencies on labor
edit reports (and other places) due to the splitting of direct hours and the
problem and can either knock some sense into me or at least offer some sound
resolution.
Thanks.
Mark Wesley
DRI/Primex
256-835-1660 X367
Mark,
Todd Anderson
resolution.
Thanks.
Mark Wesley
DRI/Primex
256-835-1660 X367
eGroups Sponsor
<http://adimg.egroups.com/img/9667/13/_/411782/_/972667424/WarningToys468x60
2E.gif>
