We are currently implementing Epicor 10 and by design have multi assembly parts where the sub assembly parts hold user defined (UD) fields depending on what production process the sub assembly part is progressing through. Obviously getting all the required fields into a single result makes priting out a document that may well contain details from the finished part, the printed part as well as the extruded part a trivial exercise.
I want to end up with a single flat record containing the relevant UD fields from each of the “-E”, “-P” and finished part in a single record, i.e UD_10, UD_11, UD_20, UD_21, UD_30, UD31 What is the best way to do this via a BAQ.
Obviously all UD fields are held against all part records but they are all unique to the sub assembly so a UD field will only be held against the finished part or the -P or -E part not all parts.
Initially I thought about selecting the Finished part then linking the parts table twice to itself with the where statement forcing the -E or -P as part of the part number but this ended in failure! I know I will have to use subqueries but am a little stuck as how to do this at the moment. I would have no problem writing this directly in SQL but the BAQ designer has me stumped at the moment with regards to subqueries.
Yes, UD_10 … etc are UD fields held in the part table.
I was just trying to show how UD_10 will only ever hold data against the finished part and UD_20 only ever against the Extruded Part. The only link between the 3 parts is that they start with the Customer Number ABCD/1000, the finished part not containing any postfix.
Yes … and I want to return back a single record with only the UD fields from the sub assembly parts that have them:
BAQ should return one record per finished part:
Make 2 inner subqueries. Assuming subquery 1 is your top level …
Subquery 2 (name it ExtParts)
Table: part (it will be given the alias part1
Display columns:
Company
UD_20
Calc field Ext_PN, with the expression (case when CHARINDEX('-E', Part1.Partnum) <> 0 THEN LEFT(Part1.Partnum, CHARINDEX('-E', Part1.Partnum)-1) ELSE '' END)
Subquery 3 (name it PntParts)
Table: part (it’ll be named part2)
Display columns:
Company
UD_30
Calc field Pnt_PN, with the expression (case when CHARINDEX('-P', Part2.Partnum) <> 0 THEN LEFT(Part2.Partnum, CHARINDEX('-P', Part2.Partnum)-1) ELSE '' END)
Link the ExtParts subquery to the part table in your top level query with part.partnum = ExtParts.Ext_PN & part.company = ExtParts.company
And similarly for the PntParts sub query
edit
Not sure if the -1 is needed in
The intent of that formula is to set the ExtParts.Ext_PN to either blank ('') - when -E is not on the P/N, or to the characters leading up to the -E. Ex: ABC -> '', ABC-E -> ABC
