We had the same situation at our company where we had two companies
sharing material, people, etc. Rather than setting up multilple
companies in Vantage, we set each company up as a division. This way
you could setup different financial for each company using divisions
and also consolidated. If anything had to be allocated or assigned
to a different company(division)a simple journal entry could just
reclass it. It served our purpose. We had the separation we needed
as well as the consolidation.
--- In vantage@yahoogroups.com, "Courtney LeBlanc" <cleblanc@p...>
wrote:
> It seems like the Multi-site module will do exactly the opposite of
> what I would like to achieve. (Single Company, Different Locations)
> Here is my current scenario;
> (3) companies under one roof which share resources(Labor &
> Workcenters)
> Due to the (3) different companies and a requirement for (3)
> different finacial records, I do not know how to measure Load &
> Capacity across (3) different "Companies"
> For now all i can do is duplicate each company's set-up.
> Is "Multi-Plant" my solution? I have not looked into this yet.
> Courtney
