Multi-Company, Multi-Customization
Hi Ted,
I tried that first, doesn't work. The wrong Customization opens (at times) and some fields that are hidden in one show in another its buggy as hell.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Tue, Sep 22, 2015 at 4:50 PM, Ted Koch tkoch77@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><div style="color:#000;background-color:#fff;font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:13px;"><div>You can create the customization (Cust1) in company A, then go to company B and open Cust1 modify it and save as Cust1.</div><div><br></div><div><span>Then you just need one menu item in menu maintenance with Cust1 selected.</span></div><br>  <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:13px;"> <div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"> <div dir="ltr"> <hr size="1">  <font face="Arial" size="2"> <b><span style="font-weight:bold;">From:</span></b> &quot;Jose Gomez <a rel="nofollow" target="_blank" href="mailto:jose@...">jose@...</a> [vantage]&quot; &lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt;<br> <b><span style="font-weight:bold;">To:</span></b> Vantage &lt;<a rel="nofollow" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt; <br> <b><span style="font-weight:bold;">Sent:</span></b> Tuesday, September 22, 2015 3:18 PM<br> <b><span style="font-weight:bold;">Subject:</span></b> [Vantage] Multi-Company, Multi-Customization....<br> </font> </div><div><div class="ygrps-yiv-8594938h5"> <div><br><div>
So we have 10 different companies in this multi company installation, each company has a slightly different customization they want done in SalesOrderEnry
In E10 I can set the a new menu item for each company and set the "Company X Only Flag" so I end up with a setup like this
Sales Order Entry -C SO_CustCompanyX -Cust X Only
Sales Order Entry -C SO_CustCompanyY -Cust Y Only
Sales Order Entry -C SO_CustCompanyZ -Cust Z Only
Sales Order Entry -C SO_CustCompanyA -Cust A Only
etc...
the end result is that each company has ONE Sales Order Entry customized to their liking.. #AWESOME!
Here is where the setup falls apart, Process Calling Maintenance is not company aware, thus if I add an entry to Process Calling Maintenance to fix the "Open With" setup I have to provide a menu ID which will be invoked.... and thats my problem... I can't create one of these per company...
Does anyone have ideas? I tried naming the customizations all the same and setting the Company X only flag in the customization side. But that does not work.
Jose C Gomez
Software Engineer
</div>
<div style="color:#fff;min-height:0;"></div>
etc...
Jose C Gomez
Software Engineer
Could you create a new menu item / form that just serves as an intermediary? It would figure out which customization is correct and then launch the real SO Entry form with that customization applied?
Sent: Tuesday, September 22, 2015 3:18 PM
To: Vantage
Subject: [Vantage] Multi-Company, Multi-Customization....
etc...
Jose C Gomez
Software Engineer
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[Image removed by sender.]<http://www.linkedin.com/in/josecgomez> [Image removed by sender.] <http://www.facebook.com/josegomez> [Image removed by sender.] <http://www.google.com/profiles/jose.gomez> [Image removed by sender.] <http://www.twitter.com/joc85> [Image removed by sender.] <http://www.josecgomez.com/professional-resume/> [Image removed by sender.] <http://www.josecgomez.com/feed/>
Hi Joe,
Yeah I thought of that too... however it seems so incredibly wrong hahaha I was hoping there was a reasonable solution that didn't involve a "HACK" I will resort to that though if I must. I think if I put the code on Form Load it might be able to kill the "intermediate" form before it even renders so the end user will just notice a slight delay in the open with launch instead of a weird flicker on / off. I might even be able to call a different form (UD Form) that is much smaller than Order Entry.
Jose C Gomez
Software Engineer
On Tue, Sep 22, 2015 at 3:29 PM, Joe Englert englertj@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>Could you create a new menu item / form that just serves as an intermediary?  It would figure out which customization is correct and then launch the real SO Entry form with that customization applied?
To: Vantage
etc...
Jose C Gomez
Software Engineer
</div>
Agreed about the hack. I knew you’d already tried the graceful solutions though.
Sent: Tuesday, September 22, 2015 3:33 PM
To: Vantage
Subject: Re: [Vantage] Multi-Company, Multi-Customization....
Hi Joe,
Jose C Gomez
Software Engineer
On Tue, Sep 22, 2015 at 3:29 PM, Joe Englert englertj@...<mailto:englertj@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
To: Vantage
etc...
Jose C Gomez
Software Engineer
T: 904.469.1524<tel:904.469.1524> mobile
E: jose@...<mailto:jose@...><mailto:jose@...<mailto:jose@...>>
From: "Jose Gomez jose@... [vantage]" <vantage@yahoogroups.com>
To: Vantage <vantage@yahoogroups.com>
etc...
Jose C Gomez
Software Engineer
