Multi Company - Kinetic Homepage
Has anyone managed to modify the Kinetic Homepage based upon which is their current company in a multi-company setup?
you mean colors, logo, background, and stuff?
Yeah, a different logo for each company for example
I can see that you can set a user to use a default homepage style however it would be handy if there was the ability to set a default homepage per company.
Anyone got any ideas?
EDIT - I have found in Company Maintenance that you can set a default homepage per company but that does not seem to do anything when you switch from one company to another.
there are two places you want to take a look at:
  • Settings > General Operations > Theme Maintenance
  • Company Maintenance > Logo Image
also, can try with different colors just to be safe:
The colours part works as can be seen. I have two different Homepage layouts for the two different companies. I have access to both companies and when i switch the layout stays the same.
The adding of the logo works in that it can be seen in the side menu for the company it is set to.
